23839 Discussions
Sound problems
VKudr1
We have a problem with the sound. The latest drivers cause temp sound loss. The sound returns after speakers mute-unmute in Windows sound properties.
We made the test on IPC AOpen 67-ha with DisplayPort and DVI. The sound comes from the IPC(computer) to the display via DispayPort. Intel Display Audio device is the default. The sound appears to be in the system, but not on real device.
The sound works fine through dvi. If two displays plugged in (using DisplayPort and DVI) the sound is okay.
Allan_J_Intel1
Thanks for joining the graphics community.
I understand you have problem after loading latest video drivers for Intel® HD Graphics 3000 .
I have noticed based on DirectX report that you are currently on Windows Embedded Standard.
Please bear in mind Intel provides support for Windows* 7, Windows* 8 and 8.1 for your graphics controller and the drivers for Windows Embedded might cause issues.
Please test using the latest video drivers here:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3319&DwnldID=23764&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000&DownloadType=Drivers&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3319&DwnldID=23764&ProductFamily=Graphics&ProductLine=Laptop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000&DownloadType=Drivers&lang=eng
Select the operating system version and download appropriate drivers for your graphics controller:
Allan.
