23083 Discussions
Spontaneous change of the RGB scheme in full-screen games
ДНови
Hello. Could you help me.
I have a laptop ASUS K550V (OS - Windows 10 x64).
It has two video cards:
Intel (R) HD Graphics 530
and
NVIDIA GeForce GTX 950M
And the problem is that when you start some games in full-screen mode - the color of the monitor changes (the image becomes more red).
And if you run the game in a separate window, then everything is fine.
As it happens you can see on the video in the application. I took it off to the phone because the problem does not show itself on the screenshots.
AlHill
Because you have dual graphics, you MUST use the drivers provided by ASUS. Also, ASUS is solely responsible for support of your laptop.
Contact ASUS for support.
Doc
LeonWaksman
  1. You should address this question to Asus.
  2. You should also instal the Graphic driver published in Asus from Asus site and the NVIDIA driver from NVIDIA GeForce site.
Leon
