23539 토론
Still No fix for this bugs
Khalilbel
초보자
4,938 조회수
still no fix for this bugs after many update drivers release
Figma ID 15013106831
Yuzu Emulator ID 14017925912
Apex Legends ID 15013099189
0 포인트
9 응답
IsaacQ_Intel
직원
4,886 조회수
Hello @Khalilbel
According to our information, the fixes for those issues are the followings:
1.      How to Fix The Yuzu* Nintendo* Switch Emulator Crashing When Loading on Intel® Arc™? The fix for this issue is included in the Intel graphics driver version 31.0.101.4382 and newer.
The Figma issue is under investigation, Intel will provide more information once it is available.
And the Apex issue ID is not on our system, can you please verify if that is the correct number to do further research?
Isaac Q.
0 포인트
Khalilbel
초보자
4,859 조회수
the code is correct of apex and yuzu still same issue no fix for latest driver for intel UHD 750 and try use DDU to remove driver and install it again no fix
0 포인트
Khalilbel
초보자
4,852 조회수
same crash and same problems i talk about before
Intel UHD 750 big issues
this what i got when the crash happen and distortions on the screen
0 포인트
IsaacQ_Intel
직원
4,836 조회수
Hello @Khalilbel
Thank you for your reply.
Please provide us with the following information:
Also, let us know the game/software version of:
·        Figma
·        Yuzu Emulator
·        Apex Legends
Isaac Q.
0 포인트
Khalilbel
초보자
4,824 조회수
Hello @IsaacQ_Intel
you can get report files below
all apps is update to latest version. i just got the outlast trials same problem
other game work fine fortnite and naruto shippuden ultimate ninja storm 4 and naruto to boruto shinobi striker GTA 5 ..
0 포인트
IsaacQ_Intel
직원
4,813 조회수
Hello @Khalilbel
Isaac Q.
0 포인트
JayB_Intel
직원
4,408 조회수
Hello Khalilbel,
I hope you are doing well. We would like to check if the Figma concern will be resolved by the latest driver release 2/26/2024. Kindly download and install the driver version: 31.0.101.5333 and let us know it was able to fix the issue.
If the issue persists kindly send us logs and crash dumps. You may see the steps below, for your reference:
Gather Application logs from Windows Event viewer "Windows Logs"
  • Press the "Windows key" + "R" and type in "eventvwr.msc", then click “OK” to run the Event Viewer.
  • Under "Event Viewer (Local)" > "Windows Logs", select the Application - to collect "Application Logs".
  • To Save the event log. Click menu "Action" and select "Save All Events As…".
  • Save the log file with your desired file name and location.
Generate Windows dump file to help us with the analysis of your concern - https://learn.microsoft.com/en-us/troubleshoot/windows-client/performance/generate-a-kernel-or-complete-crash-dump
  • Follow the "Manually generate a memory dump file" procedure from the link. This command notMyfault.exe/crash will trigger BSOD which is part of generating dump file. Make sure that this data is saved and all closed prior executing this program.
  • These are just examples of where the dumped files are normally located. The location might've been changed prior to running the tool from your end.
    • Small Memory dump - C:\WINDOWS\Minidump directory.
  • The Kernel and Complete Memory Dump - %SystemRoot%MEMORY. DMP.
    • Note: The Kernel and Complete Memory Dump is a huge file(approximately around 2GB). We would suggest to consider sharing it with us via Google Drive. It is important for us to gather all the information necessary to provide you a better recommendation in resolving your concern
We will be waiting for your response. Have good one!
Jay B.
0 포인트
JayB_Intel
직원
4,359 조회수
Hello Khalilbel,
Were you able to check the previous post? Let us know if you still need assistance.
Jay B.
0 포인트
NormanS_Intel
중재자
4,321 조회수
Hello Khalilbel,
Thank you for understanding.
Norman S.
0 포인트
응답
