22796 Discussions
Suggestions on solving dual 2560x1440 monitor issues with HD Graphics 620?
NBlan2
I have a Latitude 7400 laptop with HD Graphics 620 which connects to two Acer 2560x1440 144hz monitors (model: XF270HU) through a Dell WD19 monitor dock. I am having an issue where only one monitor will function properly at a time, while I can only set the other monitor to 1920x1080 in display settings. Additionally, when I look at the actual resolution being displayed by the monitor by looking at the monitor's on board settings, it is only displaying 1920x540. I know that the monitor works fine, as when I unplug the 'working' monitor, the one which appears not to function begins to work correctly.
I have made sure the HD Graphics 620 driver is up to date, as well as the driver for the dock. Please let me know what additional information I can provide to help solve this issue, thanks!
AlHill
You should contact Dell regarding capabilities and support of their dock.
Doc
NBlan2
Thanks Doc,
I will also contact them separately. Similar to the UHD 620, the specs online for the Dell doc should be able to support my monitors.
Nick
