23102 Discussions
Support for dual displays with DH55PJ Desktop Board
Will the DH55PJ desktop board support simultaneous independent dual displays? I have 2 VGA monitors, one connected directly to the VGA port and the other connected via a VGA to DVI-D converter but cannot seem to get the second monitor with the converter to get recognized. I have checked through the BIOS for a setting as well as the Intel graphics application and Windows Display Options. Any suggestions?
i have same problem and have no answer or help
http://communities.intel.com/thread/19113?tstart=30 http://communities.intel.com/thread/19113?tstart=30
SShah25
I had the same problem. Turns out that I didn't know the difference between DVI-I and DVI-D. The DVI on the board is a DVI-D display connection, which only gives a digital output. You'll need a monitor that has a DVI-D (or DVI-I) input. Simply using a DVI to VGA adaptor and connecting your VGA monitor won't work.
