23075 Discussions
The Sims 3 not launching on Intel Arc A750
patrick_spieler
Although this is probably not a high priority, it would be nice to see The Sims 3 working on Intel Arc. There is a large community still playing the third game despite all its technical challenges, which might also make it harder to get playable on Arc.
I use an Arc A750 and have the latest Beta Driver (31.0.101.4148).
I try playing the Steam Version of Sims 3.
It starts the launcher, but when trying to start the game from there it waits a moment and then everything is closed and Steam shows, The Sims 3 is no longer running.
On earlier drivers I also tried the EA Launcher Version of The Sims 3 and starting the .exe dircetly (with or without compatability modes).
The game was working on Windows 11 before with my GTX 970.
Any ideas or help is welcome!
patrick_spieler
I have found the solution and to my suprise it is not an Arc (drivers) issue!
The Sims 3 has problems with Intel Alder Lake CPUs. There is a patch however. So that's not on Intel!
https://answers.ea.com/t5/Technical-Issues-PC/Sims-3-won-t-open-Alder-Lake-Intel-12th-gen-CPU/td-p/11057820
Thanks for the help and sorry for the confusion!
Hugo_Intel
Hello patrick_spieler
Thank you for posting on the Intel Communities. I am sorry you are experiencing issues when trying to play The Sims 3 on your Intel® Arc™ A750 Graphics. Please share with us the following information to assist with this issue:
Hugo O.
patrick_spieler
Hello Hugo,
better late than never, so here we go:
  • Resizeable Bar is active.
  • See both the log file and a short clip of the issue attached.
Best regards
Patrick
Hugo_Intel
Thank you for the information. Please let's try the following:
Hugo O.
patrick_spieler
Thanks for the ideas. However, the issue still persists. There's also no change to what happens.
patrick_spieler
Hugo_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Hugo O.
