22968 Discussions
The computer cannot light up after manual restart with ARC B580
kinopio
Graphics card : ARC B580 CPU : i5 10400 Motherboard: MSI B460M BOOMBER The computer cannot light up after manual restart, and it seems that the graphics card is not working. I have to force a shutdown and restart to light up the screen. This problem occurs every time the computer is restarted.
kinopio
There is another issue, my monitor is 75Hz, but after installing B580, the refresh rate automatically decreases to 60Hz. If I manually adjust the refresh rate to 75Hz, the resolution will automatically decrease to a very low state
n_scott_pearson
This is often an indication of a poorer quality (or failing) cable. You could try a better quality one.
Hope this helps,
ArielP_Intel
Hello kinopio,
Thank you for posting in Intel Communities! I'm sorry to hear that you're having issues with your graphics card.
Could you please provide the following details to help us assist you better:
  1. What driver version do you currently have installed?
  2. Have you tried updating your BIOS to the latest version?
  3. Did you perform a clean installation of the graphics drivers?
  4. If you had a different graphics card previously, did you use DDU (Display Driver Uninstaller) to remove the old graphics drivers?
These steps will help us identify the cause and guide you through the troubleshooting process. Looking forward to hearing from you soon!
Ariel P.
Hexie9
I have the same problems. The computer cannot light up after manual restart when you press the restart butten.   But if you press the turn off butten and then the turn on butten, the computer can light up.
CPU : i5 10400f
  1. What driver version do you currently have installed?    6651
  2. Have you tried updating your BIOS to the latest version?   Yes
  3. Did you perform a clean installation of the graphics drivers?   Yes
  4. If you had a different graphics card previously, did you use DDU (Display Driver Uninstaller) to remove the old graphics drivers?  Yes
ArielP_Intel
Hello kinopoio,
I would like to follow up and ask if you've had the chance to review my previous response, where I asked a series of questions in order to better assist in finding a resolution for your issue.
Please let us know how it goes. Looking forward to your response!
Ariel P.
ArielP_Intel
Hello kinopio,
Ariel P.
Evilizer
I have this exact same issue. CPU 10400f with MSI b460
Gnep
my pc have same problem.CPU is i5 10400f and motherboard is MSI B460M.
