23552 Discussions
The new Intel Graphics Software control panel causes high CPU usage from WMI provider host
dantmnf2
After updating to the 101.6325 driver, the WMI provider host process constantly takes 8%~15% CPU. Quite annoying on a Ultra 7 258V system.
Uninstalled the new control panel and it calmed down.
Girofox
No need to rollback, just uninstall Intel Graphics Software under Apps but keep the rest.
No more WMI activity in task manager then.
Kayfee
Hey what is the progression of this issue ? Will we ever get a solution?  And why this issue isn't being a KNOWN ISSUE in the driver's release note yet?
Girofox
Still not fixed despite several new driver updates. Nothing in the changelog yet. For now i uninstalled Intel Graphics Software until it is fixed.
Not even mentioned under known issues.
This is from changelog pdf:
Date: January 29, 2025
Driver Version: 32.0.101.6557 Non-WHQL and 32.0.101.6262 Non-WHQL
jilherme
don't forget to add a "Kudo" to the main post here
Girofox
Update
The issue seems fixed after installing cumulative update KB5050094 which results in Windows build 24H2 26001.3037!
WMI process usage is completely zero for now, even when opening Intel Graphics Software!
So the issue was on Microsoft side the whole time, very weird. Can't find anything about WMI in Microsoft changelog. I only know that in Event viewer there were tons of WMI log relating to Nvidia too. Maybe this was related.
Girofox
Fixed after installing cumulative update KB5050094
Good news, the WMI process usage is zero for me after installing the latest cumulative update, resulting in build 24H2 26100.3037
So the issue was on Microsoft side the whole time. This could explain why there were so many WMI event logs relating to Nvidia too in event viewer.
Ernesto_C_Intel1
Hi @dantmf2,
Kindly check @Girofox's update - installing cumulative update KB5050094 resolves the issue with WMI.
With this in mind, it would be best to obtain this update using the application: Check of updates.
If you need assistance with updating your operating system, please continue working with Microsoft Support.
I'll go ahead and close this case now. Feel free to contact us if you have any concerns or questions.
Ernesto C.
Saful
I am having the same issue. here
