22963 Discussions
The new features in EMGD VBIOS 36.2.4.3732
Hi all,
I find there are some changes in the latest EMGD VBIOS 36.2.4.3732, could you please kindly explain the usage of them:
1. Windows Embedded Compact Settings.
Whether these settings is only for WEC OS? If I install Windows 7 OS, do I need to modify them?
2. CRT/EFP Panel Configuration
This setting could be found in VBIOS kit, but I still don't understand it.In the Note,
CRT/EFP Panel # 1 – # 3: used when CRT/EFP configuration is EDIDless in Display Configuration menu.
CRT/EFP Panel # 4 - # 16: used in conjunction with Windows Embedded
Does this mean if I use EDID panel, the CRT/EFP Panel # 1 -# 3 will not have effect to the display port? What is the meaning of Windows Embedded? I find the DTDs in # 4 - # 16 is the same as # 1 – # 3, whether the DTDs should be modify by myself?
Thanks & Regards,
Lynn
Allan_J_Intel1
Thanks for joining the graphics community.
I understand you need support for EMGD Video BIOS.
At this stage, the support for this product is offered through the Intel Embedded design center group. You need to register at the link below and submit your issues:
https://www-ssl.intel.com/content/www/us/en/intelligent-systems/embedded-design-center.html https://www-ssl.intel.com/content/www/us/en/intelligent-systems/embedded-design-center.html
Allan.
