23086 Discussions
Timeout while installing driver for skylake i5-6600
DDe_F2
I recently installed a i5-6600 processor on a GA-H170-HD3 motherboard.
I did not install a videocard because I want to use the graphic controller of the cpu.
Windows 7 works fine until I try to install the Intel HD Graphics 530 drivers.
Installation of the drivers fails with a timeout.
After that the system periodically freezes for 10 minutes.
I see the following error message in the event viewer: timeout waiting for Intel(R) HD Graphics Control Panel Service
Can someone tell me how I can troubleshoot this issue?
Can someone tell me where I can find more information? E.g. logging of the drivers.
David
Allan_J_Intel1
Have you tried downloading the zip version of the latest video drivers?
https://downloadcenter.intel.com/download/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10 Download Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows® 7, 8.1, & 10
Try performing manual driver installation:
http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics Drivers — How to Manually Install a Driver in Microsoft Windows 7*
Allan.
DDe_F2
Yes. I already tried that. I tried the drivers supplied with the motherboard, and the latest version which I downloaded.
I also tried the manual installation.
Result is the same with all attempts: Installation fails after 10 to 15 minutes.
The same error message appears in the event log.
I am looking for some more detailed logging. Which hopefully explains the cause of the timeout.
Filip_Z_Intel
Please check in the Event Viewer (Right click on the Start button and it's there)
Most likely
Windows Logs -> Setup
