23728 Discussions
Triple monitors on a Intel(R) HD graphics 4600
MTiza
Hi there.
I was wondering if someone could help me here. I currently have a custom built PC with an i7-4770K CPU with a Gigabyte Z87x-UD3H Motherboard.
This motherboard has a DVI,HDMI,DisplayPort and a VGA Port.
I can connect three monitors to the DVI(primary),Display Port(secondary) and VGA (third). With this set up all three monitors work. But when i want to use the HDMI instead of the VGA the monitor wont operate unless i unplug the Display port.
Is there a way i can use the DVI,Display port and HDMI together so that i can get a better resolution on my third monitor?
Sorry if this is to vague i will be happy to expand further if needed.
Im using windows 7 and all my drivers are up to date(at least im 98% sure)
Thank you
Michael
