So this is my computer specs ( I7 8700 )
I went to this link below and download Intel® Graphics - Windows® 10 DCH Drivers
https://downloadcenter.intel.com/download/30148/Intel-Graphics-Windows-10-DCH-Drivers
but when I tried to install it. I have faced with this error below:
I'm about to remove my graphic card hence I need to switch to Intel HD graphic. How can I do this ? Please advise
Do you see "Intel UHD Graphics 630" in device manager?
If not, you need to activate iGPU in BIOS (most likely in advanced settings).
Your answer helped me solve the problem, thank you very much !
Update your windows 10 to 20H2 first.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
