- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Dear Everyone,
experiencing problems to connect two monitors with a hp probook 440 g3 i5 6300 and intel 520 graphic.
vga and hdmi connectors.
What´s the matter?
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What problems are you experiencing?
Connect the vga monitor to a vga port on the laptop
Connect the hgmi monitor to a hdmi port on the laptop
Do not use any adapters or converters
And, what operating system are you using?
Doc
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for your fast reply,
im using a converter, because both external monitors just have vga and Dvi, therefore im using a hdmi -> dvi converter.
Is this the mistake?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Converters and adapters are not supported. Some work, some do not.
What connectors does the laptop have? Which connector works, and which does not?
Explain each monitors setup, cable (both ends), adapter, etc.
Doc
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
