23806 Discussions
UE4 and B580 issue
HI3944666
I couldn't find a way to report driver issues to Intel so I thought I'd post here. Every link I followed to report a driver issue was a dead end. These were supposed to be official Intel channels so I'm a bit miffed that it's so difficult to report an issue.
I have a B580. Driver version 32.0.101.6881. The most  current version. I'm running into a problem where the ground won't render in the game I'm playing. I've attached a screenshot. The game is Blade and Soul. It isn't the other version of the game - Blade and Soul Neo. It's using UE4. I've attached a screenshot. I load into the game and the image is what I see. I can reload into the game multiple times and fiddle with different graphics settings but nothing seems to fix the missing ground problem.
Hopefully this message isn't posted in vain.
Mike_Intel
Hello HI3944666,
  1. Are you using an Intel brand Arc B580?
  2. Was it working fine before the driver update?
  3. Have you tried rolling back the driver?
  4. How did you update the driver?
Michael L.
HI3944666
Correct. I own the Intel brand B580 card. Seems to be the only one that sells at msrp.
I can't say. This is a title I recently reinstalled. It was however working fine with my previous non-Intel GPU.
No.
I'm updating the drivers via the Intel Graphics Software program that was installed along with the drivers on my initial installation of the GPU. I haven't had the card very long but I've already updated the drivers 3 or 4 times as the program notifies me of a new release.
Mike_Intel
Hello HI3944666,
Thank you for the update.
Let me ask some questions based on your reply.
  1. Let me check, are you using an NVIDIA graphics on your system before installing the Arc 580?
  2. If yes, did you remove the old NVIDIA drivers?
  3. What is your game launcher?
Michael L.
HI3944666
Yup
Yup
It's an mmo game by NCSoft and their launcher is called Purple.
Mike_Intel
Hello HI3944666,
Can you try to update the driver using DDU method and also please make sure that the BIOS of your motherboard is updated.
Please refer to the links below for the steps on how to perform DDU and the latest driver:
How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
Intel® Arc™ & Iris® Xe Graphics - Windows*
Michael L.
HI3944666
That fixed the issue.
So is there a problem with using the included Intel Graphics Software for future updates? Do I need to stick with using DDU before every driver update?
Regardless, I will probably not update drivers for a while. Just save myself the headaches of something possibly breaking.
Thanks for the help. Cheers.
Mike_Intel
Hello HI3944666,
Thank you for the update and I am glad that the issue is now fixed.
To answer your questions. That depends on the system, in your case, you are using NVIDIA graphics before, and it seems like the system did not totally remove the old driver and remnants of it still remains that is having conflict with the new driver. That is why we have this recommendation to make sure that the old driver is totally removed.
Since the issue is now fixed, I need to close this inquiry.
Michael L.
