23468 Discussions
UHD 620, 4K, 60Hz, RGB over HDMI
MartinT
Hey,
Is this combination possible? Lenovo T480s connected to a Samsung QB55R (only has DVI and HDMI). I can get 4k@60Hz using a USB-C to HDMI cable, but it's 4:2:2 (8 bit). I can also select 4k@30Hz and it's at 4:4:4 (8 bit).
I've been trying to get 4k@60Hz 4:4:4 but at this time wondering if that's even possible.
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
MartinT
Utility results attached
n_scott_pearson
FYI: Lost of good information regarding transmission rates possible can be found here: https://en.wikipedia.org/wiki/DisplayPort.
MartinT
Slight bump. If someone could confirm if this chip can or cannot run 4K, 60Hz, RGB using a USB C to HDMI I would appreciate it.
MartinT
One more bump to see if I can get confirmation about this chips capabilities.
