23829 Discussions
UHD 620 compatibility
Bertsailor
I run the UHD 620 graphic driver on my Dell Inspiron 5570, Windows 11. Weather underground's wundermap will not display when the driver is enabled. It does display when the driver is disabled. What could be the problem?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Waiting for Windows 12]
