23848 Discussions
UHD 730 Max Resolution issue
tde1
I am having the same problem as the below poster (who abandoned his thread):
https://community.intel.com/t5/Graphics/Max-Resolution-1920x1080-with-UHD-730-and-I5-12400/m-p/1397300
I am also running a new Dell I3910 (Windows 11) with UHD 730 and i5-12400 which won't allow resolution setting to be selected higher than 1920x1080. Unlike original poster, I have a Samsung monitor model #LU28E510DS/ZA which should be able to display 3840x2160. Monitor is not new and previously ran higher resolution attached to a Mac. I am connecting it with the same HDMI cable that it used to connect to the Mac with.
Before seeing the original post, I updated monitor drivers, Windows, and Intel Graphics drivers. After seeing the post, I also updated Dell drivers. Problem persists. To answer the questions that the OP did not:
1) Problem has existed since I got it out of the box yesterday
2) I do not have an extra monitor that I can easily try
3) Dell drivers are now updated.
Any ideas?
megan3000
Valued Contributor I
HDR is off by default, if you haven't activated it, it must be off already and you don't need to think on "how to turn it off". In fact, you shouldn't be able to enable HDR because the HDMI port on this system is HDMI 1.4b and you need HDMI 2.0 for HDR (or DisplayPort)...
This is not a graphics/driver issue, it is simply a bad and incomprehensible decision by dell to install a low-quality HDMI port and limit its capacity... look here, they're put an HDMI 1.4,
https://www.dell.com/en-us/shop/desktop-computers/inspiron-desktop/spd/inspiron-3910-desktop/nd3910fsgsh#tech-specs-anchor
but that's not the whole picture of the issue,  they actually confirmed that HDMI cannot output resolution higher than 1920x1080 due to "motherboard design limits". Your computer model is on the list:
https://www.dell.com/support/kbdoc/en-us/000126548/resolution-on-external-monitor-limited-to-1920-x-1080-using-hdmi
If both the computer and the monitor have a display port connection, you can try using a display port cable, it should allow 4k.
Avihaa
As for the table that you provided, the driver and Intel® UHD Graphics 730 supports 4K@60hz in 10-bit mode with 4:2:0/4:2:2 subsampling via HDMI 2.0/DP 1.2. When you enable HDR it normally defaults to 8-bit with dithering (equivalent to 10-bit) and 4:2:0 as this is what the Operating System currently supports.
tde1
Thanks, Avihaa... So it sounds like I need to turn HDR off in order to have 10-bit as an option which will then allow me to increase my resolution. How do I turn off HDR?
megan3000
schizomer
Thank you. I am having the same issue. I have a Dell 3910 with UHD 730 graphics trying to get it to display 3840x2160.
The weird thing is I had it running 4k just fine until Windows automatically updated my driver recently. I tried rolling back the driver or using older ones, but no luck. I may have been using another driver altogether.
Would it be a bad idea to try to find another driver that does display 3840x2160?
How badly could I damage my computer if I did?
Edit: I was able to find an older version of the driver that works. I just wasn't going back far enough. Version 30.0.101.1660 seems to work. Anything newer goes back to 1080p max.
https://www.intel.com/content/www/us/en/download/19344/727284/intel-graphics-windows-dch-drivers.html
If after you install it Windows Update tries to auto-update the driver, just let it finish and after it's done, roll-back the driver from Device Manager and it should be good.
tde1
Thank you, Megan. Much appreciated.
DeividA_Intel
Hello tde1,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® UHD Graphics 730.
Before we continue further I would like to know if the recommendation from the community members were helpful or if the issue persists.
Please let me know if you need further assistance.
Deivid A.
tde1
Yes, megan3000's post was helpful. I ended up getting a displayport cable for my existing monitor and using the HDMI for my second, lower resolution screen. Thanks for checking in.
DeividA_Intel
Hello tde1,
Thanks for your confirmation. I am glad to know that you found a solution.
I will close this thread, however, you can open a new one in case you encounter any issues with Intel products.
Deivid A.
schizomer
I was having the same issue. Try downloading an older version of the graphics driver. I am also using a Dell 3910 with UHD 730 graphics.
Version 30.0.101.1660 seems to work fine. I'm able to set it to 3840x2160. Anything newer goes back to 1920x1080 max.
If Windows Update auto-updates the driver, let it finish and after it's done, go to Device Manager and Roll Back the driver. It should be good until Windows Update tries to update it again. If it does, just reinstall it again I guess.
Dewdman42
Thanks so much for the solution with the older driver.  Works perfectly at full 4k resolution.  I get what people are saying that this Computer has a "crappy" 1.4 HDMI port on it...but then again...with the older driver it works at full resolution so there is something more to the story...   Kind of disappointing that Dell or Intel is trying to disable full UHD resolution when obviously the 1.4 HDMI port and cable can handle it just fine.
I will probably just get a DP cable anyway so that I don't have to worry about it, didn't come in the box with the monitor I got, but still its nice to know HDMI can be made to work at full resolution by simply reinstalling the older driver.
Anyone have any ideas why this may or may not be a bad idea to use the old driver?  is it doing lower frame rate or anything.  Seems fine to me here right now I'm typing this in crystal clear UHD resolution.
Computer is brand new Dell Inspiron 3030, 14th gen i5, with Intel UHD 730, so I don't know maybe these HDMI ports are more capable then people are saying or thinking and for some reason the newer driver is not taking advantage of it while the older driver is at least allowing it to go through?
its showing up as 8bit under Win 11 advanced display settings, so that might be where the trade off is with trying to cram 4k resolution through HDMI 1.4b.  Looking online I see that that HDMI 1.4 supports 4k video though...so I'm not really sure why Dell and Intel are crippling this one down to HD while using HDMI port.  Very Strange.
