23660 Discussions
(URGENT) Help me update my graphics driver
TTony8
Hi there,
I am not sure which graphics driver do I download for my laptop in order to update it... My graphics card/driver that is currently installed in my laptop is a Intel HD Graphics 4400 but when I search for my graphics driver in Intel Graphics driver search (https://downloadcenter.intel.com/search?keyword=Intel%C2%AE+HD+Graphics+4400 Search downloads) , I do not know which ones to download. I am so confuse and I need help asap as I have spent weeks trying to find out which one to download.
This is my processor information.
PROCESSOR INFORMATIONManufacturerIntelModelhttp://www.intel.com/p/en_US/support/ Intel(R) Core(TM) i7-4510U CPU @ 2.00GHzIntel HD Graphics 4400Current OSWindows 10 64BitCPU RevisionCPU Type00CPU Family06CPU Model45CPU Stepping1
The above information is provided to you all by me because I need to know from you which graphics driver do I need to download so i can update my current driver. If possible, can you also provide me the link for the download. Thanks.
P.S. Also intel Driver Update Utility did not work for me so that is why I need to do this manually.
AlHill
Use the first on in this list:
http://www.intel.com/content/www/us/en/support/graphics-drivers/intel-hd-graphics-4400-for-4th-generation-intel-core-processors.html Intel® HD Graphics 4400 for 4th Generation Intel® Core™ Processors
Doc
TTony8
Hi Doc,
Thanks for your lovely reply.
So you're telling me to click on the link you provided to me and then in that link click on the https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Intel® Graphics Driver for Windows® 10 [15.40][4th Gen] to install the driver for my current driver??
  • Date: 12-Aug-2016
  • Version: 15.40.28.4501 (Latest)
  • OS: Windows® 10, 64-bit*
Also, just curious you did look at my specifications/report of my processor?? I want to know if the https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
is the right one for my current driver? I do not want to install a wrong driver.
AlHill
Yes, and yes.
First, I looked at your processor to verify that it had HD Graphics 4400:
http://ark.intel.com/products/81015/Intel-Core-i7-4510U-Processor-4M-Cache-up-to-3_10-GHz Intel® Core™ i7-4510U Processor (4M Cache, up to 3.10 GHz) Specifications
Then, armed with that information (4th gen processor, and 4400 graphics) I went here:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
I scrolled down the list until I got to 4th gen processor and 4400 graphics.
Yes, you are supported on Windows 10. So, I clicked on that link and it took me to the list you just visited.
Doc
TTony8
Ok thanks so much.
I will install this right now and then I will see if it works .
Do you recommend me to install the Exe version or the Zip file?
AlHill
Personally, I do the zip files. You can do either. If the exe fails, then the zip is a second chance.
Doc
TTony8
Okay sounds good. Will do your method . Will let you know the results . Still downloading.
Hello OneOfAKind,
I hope you can have a good experience with the driver Al Hill provided to you and yes that is the correct driver for your system.
Thanks Al Hill for the information.
Best wishes,
Ivan
I was reviewing this thread and I would like to know if you were able to resolve your problem or if you need further assistance.
Ivan.
