Received notice to download driver
Intel® Arc™ & Iris® Xe Graphics - WHQL - Windows*
Has anyone else have same issue?
Hello, @1HatLady
I am sorry to hear what is happening with your Intel® Driver & Support Assistant (Intel® DSA), I will gladly assist you here.
According to the Troubleshooting Intel® Driver & Support Assistant (Intel® DSA) Error Messages article, this error means that the Download failed while in progress.
Please, check that your internet connection is working properly and try it again. Let us know if the issue persists.
Jocelyn M.
I am connected to the Internet for I am able to download or upload to other websites.
For this particular driver is not downloading, all others have without problems. Also, I turned off VPN, still won't download.
I tried again, and same results.
Hello, @1HatLady
Then, try the following steps for this issue:
- Ensure both the Intel® DSA Service and Intel® DSA Updater service show status of Running.
- In Windows* Search, type Services and scroll to find Intel® Driver & Support Assistant.
- Confirm the Status shows Running; if it isn't Running, then start the service if necessary by right-clicking and choosing Start.
- Check to see if any Windows* updates are pending. If yes, restart the system after the updates are installed.
- Clear the browser cache and close the browser.
- Try rescanning Intel® Driver & Support Assistant (Intel® DSA), ensuring browser being used is Firefox, Chrome, or Edge Legacy, these are the only web browsers supported for this tool.
- Try disabling your Ad Blocking extensions and privacy related extension on the Intel® Driver & Support Assistant (Intel® DSA) webpage.
- If the previous steps didn't work, uninstall the Intel® DSA using the IDSA Uninstaller and test it again.
Jocelyn M.
Yes I was able to finally download.
Thank you.
Hello, @1HatLady
Thank you for your reply, I am happy to hear that your IDSA works fine now.
Since your issue is solved, we will proceed to close this thread now. If you need any additional assistance, please do not hesitate to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
