23840 Discussions
Unable to Install Intel Arc Control
Fadi81
hello there,
I been trying to update Intel Arc Control on my laptop for so long and i never made it, then I've decided to Uninstall the Intel Arc Control to proceed with a clean Installation but unfortunately it didn't work again and I'm getting ( No driver was found that can be installed on the current device. Installer exit code:8.
Please advice
DhannielM_Intel
Hi Fadi81,
Thank you for posting in the community. I'm curious about a few details since you're using a laptop. Could you please provide the exact model of your laptop? Additionally, are you using the latest GPU driver version available on the Intel website?
To gain a better understanding of your system, please use the System Support Utility (SSU) to generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here: Help Guide for the Intel® System Support Utility
Furthermore, I want to inform you that Intel Arc Control is associated with older graphics drivers. The new application for the latest graphics drivers is Intel Graphics Software (IGS).
Dhanniel M.
Fadi81
Operating System: Microsoft Windows 11 Home(10.0.26100 Build 26100)
Physical Memory (Installed): 32 GB
Processor: 12th Gen Intel(R) Core(TM) i9-12900HX
System Type: x64-based PC
Total Installed Updates: 17 Updates - See Detailed View for more information
Display Adapter(s): NVIDIA GeForce RTX 3080 Ti Laptop GPU 32.0.15.7260
System Manufacturer: LENOVO
System Model: LNVNB161216
Network Adapter(s): Bluetooth Device (Personal Area Network) 10.0.26100.1150
Killer(R) Wi-Fi 6E AX1675i 160MHz Wireless Network Adapter (211NGW) 23.120.0.3
Realtek Gaming 2.5GbE Family Controller 1125.8.515.2022
Disk(s): SAMSUNG MZVL22T0HBLB-00BL2 1.26 TB (available) 10.0.26100.1150
Samsung SSD 990 PRO 4TB 3.08 TB (available) 10.0.26100.1150
Fadi81
Yes I'm using the latest GPU driver version available in the intel website, and i been trying to install the new application for the latest graphics drivers INTEL GRAPHICS SOFTWARE (IGS) but its not working so far, it will stop during the installation and I'm getting the message i mentioned previously with code 8.
DhannielM_Intel
Hi Fadi81,
Thank you for sharing your thoughts on this matter. I'm curious to know the exact model of your laptop and the latest GPU driver version available on the Intel website. Additionally, could you provide the System Support Utility (SSU) report that I mentioned earlier?
Dhanniel M.
DhannielM_Intel
Hi Fadi81,
I'm following up to see if you've had a chance to review my previous response. At your earliest convenience, please send the logs for further investigation.
Dhanniel M.
DhannielM_Intel
Hi Fadi81,
Dhanniel M.
