22878 Discussions
Unable to connect a Vaio FE15 with Intel UHD Graphics 620 with 2 external monitor
EMorg2
I have a new Vaio FE15, that has a Intel UHD Graphics 620 and already has Intel 10th generation (i5 10210U).
It has a HDMI output that just works fine to connect an external monitor.
It also have 2 USB 3.0 + 1 USC-C.
I bought a USB-C to HDMI adapter to connect a second monitor on it, but it just doesn't works.
UHD 620 officially supports 3 monitors (2 extend + notebook screen).
Is there something that I can do to you 2 external monitors (extended, not mirroring).
Stefan3D
The laptop must support "DisplayPort Alternate Mode", usually the port has a DP logo.
I found only another manual, but you get the idea.
2.Locating Parts and Controls
4
USB Type-C™ port (USB 3.1 Gen 2)
This port supports the following standards
.• USB charging (BC 1.2 IN/OUT)
• DisplayPort Alternate Mode
• USB Power Delivery (IN)
https://uk.vaio.com/media/pdf/dc/6b/92/QG_VAIO_SX14_V1-30-EN_190220_online.pdf
n_scott_pearson
One additional comment: While it may not be necessary for this particular laptop (presuming that it does indeed support DisplayPort Alt Mode), it is worthwhile to choose cables/adapters that also say they are Thunderbolt 3-compliant.
