23282 Discussions
Unable to get 3440x1440 on Intel HD Graphics 520
judal
I've unable to get 3440x1440 on a Philips Curved 34" Ultrawide Monitor 346P1CRH/75.
I'm only able to get a maximum of 2560x1080 through both the Display Settings and the Intel HD Graphics Control Panel.
I'm connected through a HDMI cable which works fine when plugged into other devices.
n_scott_pearson
Is HDMI your only option? The HDMI support is awful (only 1.4). I suggest you use a DisplayPort connector; this should support your resolution at 60Hz.
judal
Unfortunately I've only got a HDMI and a DVI output available, I'm using a Dell Latitude E5570...
n_scott_pearson
Hhmmm, have you tried creating a custom resolution in the Control Panel?
