23854 Discussions
Unable to initialize Open GL
Hello everybody !
I'm a french user therefore DO NOT pay attention to my bad grammar.
I've actually install DOOM 3 BFG Edition but got a problem when i try to run it.
The error is "Unable to initialize Open GL" and the following message appears :
QA Timing INIT: 000000ms
D3BFG 1.1400 win-x86 Nov 9 2012 10:38:21
2094 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT
3040 MB System Memory
64 MB Video Memory
Winsock Initialized
Found interface: {AAAF01FC-D795-4458-A872-66DD3A2B1F88} Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - 10.188.86.217/255.255.0.0
Found interface: {DEFC4BCF-A362-43ED-BCC3-066390719CF5} Atheros AR9285 Wireless Network Adapter - 0.0.0.0 NULL netmask - skipped
Found interface: {EEA28246-9ECA-4CDA-94E7-1C241C660A2E} Hamachi Network Interface - 25.137.61.153/255.0.0.0
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded resource file _common.resources
Loaded resource file _ordered.resources
Loaded resource file _sound_pc.resources
Loaded resource file _sound_pc_en.resources
Reading resource CRCs...
Current search path:
D:\Programs Files\Bethesda Softworks\Doom 3 BFG Edition/base
C:\Users\Simon\Saved Games\id Software\DOOM 3 BFG/base
file system initialized.
WARNING: Unable to open resource file maps/_startup.resources
----- Initializing Decls -----
Couldn't open journal files
execing default.cfg
couldn't exec D3BFGConfig.cfg
couldn't exec autoexec.cfg
----- R_InitOpenGL -----
Initializing OpenGL subsystem with multisamples:0 stereo:0 fullscreen:1
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' 😞 succeeded
X..WGL_EXT_swap_control_tear not found
display device: 0
DeviceName : \\.\DISPLAY1
DeviceString: Mobile Intel(R) 4 Series Express Chipset Family
StateFlags : 0x5
DeviceID : PCI\VEN_8086&DEV_2A42&SUBSYS_18621043&REV_09
DeviceKey : \Registry\Machine\System\CurrentControlSet\Control\Video\{2D5713FD-A14A-4DDE-9409-D52B1A9CEC71}\0000
DeviceName : \\.\DISPLAY1\Monitor0
DeviceString: Generic PnP Monitor
StateFlags : 0x3
DeviceID : MONITOR\SEC5441\{4d36e96e-e325-11ce-bfc1-08002be10318}\0000
DeviceKey : \Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0000
dmPosition.x : 0
dmPosition.y : 0
dmBitsPerPel : 32
dmPelsWidth : 1366
dmPelsHeight : 768
dmDisplayFlags : 0x0
dmDisplayFrequency: 60
...calling CDS: ok
display device: 0
StateFlags : 0x5
StateFlags : 0x3
dmPosition.x : 0
dmPosition.y : 0
dmBitsPerPel : 32
dmPelsWidth : 1280
dmPelsHeight : 720
...created window @ 0,0 (1280x720)
Initializing OpenGL driver
...SetPixelFormat failed
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL 😞 failed
...releasing DC: failed
...resetting display
...shutting down QGL
...unloading OpenGL DLL
...initializing QGL
display device: 0
StateFlags : 0x5
StateFlags : 0x3
dmPosition.x : 0
dmPosition.y : 0
dmBitsPerPel : 32
dmPelsWidth : 1366
dmPelsHeight : 768
...calling CDS: ok
display device: 0
StateFlags : 0x5
StateFlags : 0x3
dm...
Thank you for your reply !
Actually, my laptop doesn't seem to have the requirements for playing DOOM, indeed...
For those who got the same error, here is a link from Steam Community which explain how can you fix it (Only if your system is NOT outdated like mine...).
--> http://steamcommunity.com/app/208200/discussions/0/864949037794399234/ Fix for the OpenGL issue.
