22981 Discussions
Unable to install RST 10.1.0.1008 driver on Windows 7 x64
I'm unable ot install the Rapid Storage Technology driver 10.1.0.1008 on Windows 7 x64 (board is Intel DP55KG). The 8.9 drivers work, the 10.1.x driver doesn't. When I try to install the driver/software it takes a very long time when trying to install the driver file itself and then an error pops up.
The log IntelIRST.log shows the following error:
[INF]
Installing C:\Windows\Temp\IIF2\Drivers\x64\iaStor.inf
INF = C:\Windows\Temp\IIF2\Drivers\x64\iaStor.inf
Execute command: C:\Windows\Temp\IIF2\x64\Drv64.exe -driverinf "C:\Windows\Temp\IIF2\Drivers\x64\iaStor.inf" -flags 20 -keypath "Software\Intel\Difx64"
! DriverPackageInstall error 0x5B4
IIF will NOT initiate reboot
Exit code = 0x5B4
ResultCode = 1460
<<< 2/15/2011 22:24:33:337
The BIOS of the board is up to update (Raid controller version is 10.1.0.1008).
I don't have a definitive answer for you, but I did notice that on the download page for your mother board, for Win 7 64bit, the RST driver listed is the 9.6.1014 version. Perhaps the RST 10... driver is not compatible.
I think I already tried 9.6 as well. But I will try again...
Same thing happens: The installation of the driver takes a very long time and fails:
[Configuring uninstallation]
Uninstall key: Software\Microsoft\Windows\CurrentVersion\Uninstall\{3E29EE6C-963A-4aae-86C1-DC237C4A49FC}
[INF]
levicki
Valued Contributor I
Be carefull what you wish for... I installed it and the Windows refused to boot afterwards, had to do System restore.
