23735 Discussions
Unattended setup for Intel Graphics Command Center
tgoldschrafe
We need to deploy Intel Graphics Command Center to several machines via SCCM. But we need to adjust some settings in the application. Is there some way to achieve this (GPO, JSON, XML)?
Victor_G_Intel
Hello tgoldschrafe,
To better assist, can you please provide further details:
  1. What are you guys trying to achieve exactly? Please provide as many details as possible.
  2. What kind of environment are you guys using in terms of hardware and Sofware to achieve this?
  3. When you say “adjust some settings in the application” do you mean the Intel graphics command center or the System Center Configuration Manager?
  4. When you mentioned “Is there some way to achieve this (GPO, JSON, XML)” what exactly do you mean? Please provide as many details as possible.
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello tgoldschrafe,
Thank you for posting on the Intel®️ communities.
We noticed that you have contacted Intel®️ Customer Support directly regarding the same issue here described and we found out that you have an internal support case open. In this case, we will proceed to close this thread to avoid duplication of effort and the support will continue through the internal case.
Victor G.
Allensd69
Any chance the solution can be posted here?
