23762 Discussions
Updated Intel Iris XE Graphics Driver resolution
kimmi
My Computer updated to the newest version of the Iris XE Grapics - 32.0.1015972 and now the higest resolution y extended screen (A 4K Hisense Smart TV) can go is 1920 x 1080 whereas before this it was 3840 x 2160 which is what I need it to be. Is there a patch or previous version I can download to be able to use the higher resolution. I even bought a 4K HDMI to ensure that wasnt the problem
VARADHARAJAN
Valued Contributor II
@kimmi
Before the update, show proof of screen resolution.
After the update, show proof of screen resolution.
Thanking you
Varadharajan K
kimmi
Hi there, please advise how Im meant to get proof of the res before the update? I can send for after
VARADHARAJAN
@kimmi
After the update, screenshot please
kimmi
Here it is
kimmi
@VARADHARAJAN I also ran a diagnostic to check my secondary screen can do 4K
VARADHARAJAN
@kimmi
Which processor and model number are you using, The model number of the Motherboard, please.
Check the settings in your smart Tv, display resolution.
varadharajan K
kimmi
@VARADHARAJAN here is some of the info, where do I find the motherboard model nr?
VARADHARAJAN
@kimmi
You  are using Laptop right, model of the laptop, and bios version please, check  in system information in windows
kimmi
@VARADHARAJAN Yup using a laptop, kindly see the below required information
kimmi
@VARADHARAJAN  how come it worked before? and what can I do to correct this?
kimmi
The specs you showed are for the computer I need the higher resolution on my smart tv/my extended screen and it worked before?
JedG_Intel
Hello kimmi,
Thank you for posting at Intel Community Forums.
I would just like to confirm if you need further assistance with regards to your concern. If yes, please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I'll be looking forward to your response. Have a good one!
Jed G.
JedG_Intel
Hello Kimmi,
Jed G.
