23719 Discussions
Updating UDH Graphic Driver Problems
TJTang
I am trying to update my graphics driver and it just sits there, never completes. I tried using Intel's Assistant-Installer and then just trying to run the .exe on it's own and both would just sit there. Here is the info it gave me from the Assistant-Installer.
If anyone can give me any ideas I would really appreciate it.
PROCESSOR
Intel® Core™ i5-1035G1 CPU @ 1.00GHz
  • Device Details
  • Manufacturer  Genuine Intel
  • Description  Intel64 Family 6 Model 126 Stepping 5
  • Architecture  x64
  • # of Cores 4
  • # of Threads 8
  • Processor Base Frequency1000 MHz
  • Current Voltage 7.
  • Level 2 Cache 2048 Kb
  • Level 3 Cache 6144 Kb
  • Processor Id 0x706E5
  • Revision 32261
  • Availability Running at full power
  • Driver Details Update available
  • Provider Intel Corporation
  • Version 27.20.100.8853
  • Date 10/14/2020
  • Device Details
  • Adapter Compatibility Intel Corporation
  • Video Processor Intel® UHD Graphics Family
  • Resolution 1920 x 1080
  • Bits Per Pixel 32
  • Number of Colors 4294967296
  • Refresh Rate - Current60 Hz
  • Refresh Rate - Maximum60 Hz
  • Refresh Rate - Minimum40 Hz
  • Adapter DAC Type Internal
  • Adapter RAM 1.00 GB
  • Status This device is working properly.
  • Location PCI bus 0, device 2, function 0
  • Device Id PCI\VEN_8086&DEV_8A56&SUBSYS_868E103C&REV_07\3&11583659&2&10
