23586 Discussions
Upgraded to 11900k now GPU problems
Bemused
Build Specs:
Asus Prime Z490-A BIOS version 2601 (Latest)
64GB (4x16) Corsair Vengeance RGB Pro 3200 RAM
PSU: Corsair CX750F Fully Modular 750W
EVGA RTX3080 FTW3 (Latest GeForce drivers via GeForce experience)
MSI Coreliquid 240R V2 CPU Cooling
CPU i5 10500 upgraded to i9 11900K (Problem started)
Windows 10 64bit
Hello
Yesterday I upgraded from i5 10500 to i9 11900K
When I rebooted went into BIOS and loaded default settings (F5) then rebooted.
Windows loaded then once I logged in after about 10 seconds the screen went black, then after another few seconds the RTX3080 fans stopped but the PC was still running although KB seemed unresponsive.
After rebooting again the same thing happened so I powered down, uninstalled GPU and tried using the motherboard onboard graphics. (Intel UHD Graphics 750 Drv. V. 27.20.100.9127 04/01/2021) Rebooted and it all loaded and ran fine. I uninstalled the Nvidia geforce drivers, shut down, reinstalled GPU, rebooted and windows opened and was running fine on GPU but without drivers. I then reinstalled geforce drivers (latest) and as soon as they were installed the screen went black and GPU fans stopped.
I tried the GPU on my other PC without any issues.
I tried a MSI RTX3070 in the i9 PC and the same thing happened.
The BIOS recognises i9 11900K with Temps about 33-34degs.
So I am at a loss as to what is happening.
Any interest, advice or assistance offered will be received gratefully.
Cheers
AlHill
Do a fresh install of the OS followed by installing the chipset INF.
Bemused
OK thank you I will give that a go 👍
Bemused
Well I gave that a go but it didnt work although the 3080 stayed "alive" for about 10mins this time.
Then I tried a GTX1080 I had laying around and......... its working fine currently got Furmark stress test running and seems to be no problems so far.
Because of this Im wondering if its the PSU? Although it should be capable might try an 850W from another PC.
Steven_Intel
Hello Bemused,
In order to better assist you, please provide the following information:
For the black screen issue:
  • Have you tried connecting the monitor to a different port or use a different cable if available?
  • Have you tried a different monitor?
For the dGPU issue:
Please let me know if using a 850W PSU made a difference.
Steven G.
Steven_Intel
Steven G.
Jean_Intel
Hello Bemused,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
