23526 Discussions
Use Intel UHD graphics 620 in Windows 7?
YJeon3
The company has been given a new laptop for work.
The laptop is Windows 10 only, but the OS that should be used for the job is Windows 7.
A problem has arisen here. If you use Windows 10, some programs don't work properly and you can't work.
Windows 7 is not available for installing the [UHD graphics 620] driver in the window, so it can not be connected to an external monitor.
There are some inconveniences because graphics drivers are not installed.
We know Intel's corresponding graphics card is recommended for use with Windows 10-64 bit only.
Is there a way to install graphics drivers in Windows 7?
Stefan3D
Neither Intel nor Microsoft support Kabylake and beyond under Windows 7
Check out:
https://support.microsoft.com/en-us/help/4012982/the-processor-is-not-supported-together-with-the-windows-version-that
You would have to modify INF and disable driver signatures at your own risk as described at
https://communities.intel.com/thread/110152 https://communities.intel.com/thread/110152
This still would not help against Microsoft's blocking though.
