23854 Discussions
Using a USB only KVM switch with multiple monitors per machine
TSerg3
Like stated in the header. I have bought recently a KVM switch degined to connect 4 USB devices to 4 computers and switch between them. One of my  laptops have additional monitors attached and unfortunatelly this additional monitor is unavailable for the mouse.  Is this a issue concerned to my HD 4600  or I should rather return the KVM ?
thanks.
n_scott_pearson
Please better explain yourself. If the KVM had the keyboard and mouse connected to it and it is currently supporting PC 1, then, regardless of the other monitors connected to PC 2, PC 2 will not be able to do anything via its other monitors -- unless a separate keyboard and mouse is connected to PC 2. The keyboard and mouse connected to the KVM are only available to a OPC when that PC is the PC being supported.
