23671 Discussions
VR Driver Issues after Hard Drive Replacement
zanebullsye10
My PC's Hard Drive went caput a few days ago and after getting it replaced I can't seem to set up VR properly. What confuses me is the fact that VR worked swimmingly before with little issues, and yet now the Drivers that I'm missing I can't seem to find anything to do with.
It started with getting Error 208 on SteamVR, which usually just means that the Display for the Headset isn't found. However, after checking the Device Manager, I noticed that unlike before, there were 4 things under "Other Devices" that had the warning symbol next to them, as well as noticing that those four things that seem broken are necessary for VR.
The Devices that seem to not be working are as follows:
- BCM2045A0
- PCI Serial Port
- PCI Simple Communications Controller
- SM Bus Controller
I'm assuming that I won't be able to get VR running until these are fixed, and I can't seem to find many decent suggestions on finding their drivers online. The only fixes I've found are to Uninstall the USB Drivers so they reinstall properly, which didn't seem to work, and to try to install the latest Chipset (whatever that is, I have no clue) which only told me that it was incompatible with my PC.
Does anyone have any kind of suggestions on what I can try to alleviate the issue?
zanebullsye10
Here you go.
zanebullsye10
I've tried multiple times, the site keeps telling me I reached the posting limit.
zanebullsye10
Here, thanks for all the help by the way.
AlHill
All I can tell you is to try this download from dell for the Broadcom driver:
https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=w1pgv
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
zanebullsye10
Well that's annoying. Even the website doesn't help.
AlHill
Then you need to discuss with dell, as that is not an intel driver and it is provided by dell.
zanebullsye10
Sadly no good, all Dell told me is to get a new computer. I disagree with that sentiment for the sole reason of the computer was WORKING on Saturday, and this is only occurring because I had to replace the Hard Drive.
AlHill
Ok, let's try this.
In devicce mangler, uninstall the broadcom device, selecting the checkbox to remove the software.
Then, scan for devices and see if it reinstalls the broadcom device for you.
zanebullsye10
How do I scan for devices?
AlHill
Just right click anywhere in the device mangler and select scan....
zanebullsye10
Just like before Windows says that it gets it "Set up and ready to go," but it still has the warning symbol in the Device Manager next to it that says otherwise.
AlHill
Ok, you removed the "other device", correct?
Then, you scanned for new devices, correct?
It should have either re-displayed the other device, or it should have correctly installed it.
If it re-displayed the other device as before, there is not much I can do.
Dell has a support forum.  Perhaps someone there is more familiar with this on their hardware.
KaneSmith
You need to install your motherboard’s chipset and device drivers, once that’s done, SteamVR should detect your headset and fix Error 208.
jaslinee
Download These Drivers from the Manufacturer Website
Install in this order:
:keycap_1: Chipset Driver (VERY IMPORTANT)
:keycap_2: Intel Management Engine (MEI)
:keycap_3: Bluetooth Driver
:keycap_4: USB Drivers (if available)
These will automatically fix,
  • SM Bus Controller
  • PCI Simple Communications Controller
  • PCI Serial Port
  • BCM2045A0
Lara-Woodward
I have been in the same boat after swapping out a hard drive, it is super frustrating when everything worked fine before. From what you’re seeing in Device Manager, those warning icons usually mean your motherboard/chipset drivers aren’t installed yet. The VR headset itself is fine; Windows just can’t talk to the necessary controllers.
Here’s what I’d try:
Figure out your exact motherboard model – this makes all the difference for getting the right drivers.
Go to the manufacturer’s site (like ASUS, MSI, Dell, HP) and download the chipset drivers, Intel Management Engine, and Bluetooth drivers. That usually fixes the BCM2045A0 and PCI devices.
Install in order – chipset first, then ME interface, then Bluetooth. Reboot after each major install if needed.
Check Device Manager again – those yellow warning symbols should be gone.
Launch SteamVR – once Windows recognizes all devices, VR should detect your headset without errors.
Honestly, this is the most common issue after a fresh Windows install. It’s not broken hardware; it is just missing the system-level drivers that VR depends on. Once you get those installed, things usually snap back to normal.
