23822 Discussions
VRAM Problem
HASSAN1
Hello everyone I have intel i7-6700
With HD 530
My VRAM size is 128mb and it's not going above from 128mb
I have 20gb of ddr4 ram
Please help me to solve the problem
AlHill
You have already posted about this once.
Virtual ram, for your graphics, will allow up to 50% of your system memory, which you say is 20gb.
The 128MB you speak of is dedicated ram, which is controlled by your bios, and will likely not go above 128MB.
If you have a game that is requesting more dedicated ram, the game is broken.   Notify the game manufacturer.
Also, your processor is no longer supported.   You will receive no support from Intel.
HASSAN1
can i get more VRAM by adding more ram or not?
n_scott_pearson
Since the driver will utilize up to 50% of available system memory (based upon perceived needs), yes, more can be made available by increasing the system's available DRAM.
HASSAN1
so how much RAM I need to get 2gb of VRAM from intel hd 530?
n_scott_pearson
I would recommend you have 8GB in your PC.
HASSAN1
I have 20GB of ddr4 2133mhz ram
so what can i do
n_scott_pearson
Look, you are not listening/comprehending. You don't have to do anything. Your graphic drivers can allocate close to (in your case) 10GB of memory for use as VRAM - and will do so when needs dictate. Forget about the dedicated memory number that is being displayed; it is simply not important.
I also repeat: If you have a software, such as a game, that is complaining about not having enough memory, then this software has a bug in it. If the software will let you proceed, then do so. If not, then you need to contact its authors to have this software bug fixed.
There are also games that will allocate as much VRAM as they can and fill this VRAM is texture data, etc. These games are going something that is not supported by Intel's Graphics drivers. In this case, all you can do is contact the game designers and ask for a version that doesn't do something so utterly ridiculous.
HASSAN1
Okay I get the point.
Thanks for the Help and giving a Response.
