23822 Discussions
Video Limitation
JReed5
I have a system board (Intel Corporation D525MW) and can't get a screen resolution higher than 1280x720. I went to the download area for this board and it only shows the lan driver and no video driver. The monitor the is connected to it is an HP 2159, which is capable of a 1920x1080 resolution. The current resolution 1280x720 just looks to bad to work on.
Do I need to buy a low end video card to address the problem or is there a video driver I don't see?
Jim
Jose_H_Intel1
Hi Jim, let me help you with your issue.
The choices that are available will depend on the operating system. Please review the supported operating systems in the "Current boards" table.
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm Desktop Boards — Supported operating systems
The supported screen resolutions depend on the port used and are listed in the document below, page 19. For VGA the maximum supported resolution is 2048 x 1536 (QXGA) at a 75 Hz refresh rate.
http://www.intel.com/support/motherboards/desktop/d525mw/sb/CS-031615.htm Intel® Desktop Board D525MW — Technical product specification
