23102 Discussions
Video output is accidentally sent to TV
ISpec
1. Trying to adjust resolution for TV connected via HDMI, I've set 'Multiple Display' to 'Single Display', and this single display appears to be not monitor but TV. So, now I see black monitor screen (no signal), and black TV screen (resolution not output). Of course, when HDMI cable is plug out of TV, Video is sent to monitor, but in such a case I cannot adjust resolution for TV. Maybe, there is some hot keys to choose 'Clone display' in 'blind mode'?
2. Trying to update Intel HD Graphics, I've got version looks older than previous one. Tried both Intel Update Utility and seeking manually for my Intel Core i5 4460. Maybe, there is other way to get the latest version?
Thanks in advance
ISpec
Part 1 is solved via hotkey win+p; part 2 is not quite clear because higher modes (1920 x 1080) are related to TV monitor. However, signal on TV has been disappeared, and I'm going to create other topic for it.
Allan_J_Intel1
Did you create another topic?
Were you able to address this issue?
Allan.
ISpec
allan_intel,
I've managed to reconfigure 'multiple displays' to 'clone' via hotkey 'win'+p (there is very simple interface, and I could do it in blind).
About complete disappearing HDMI signal in TV, I've created other topic at /message/357184 https://communities.intel.com/message/357184
Allan_J_Intel1
Thanks for the information. Your topic has been assigned to one of the Intel support representatives. You will get responses soon.
Allan.
