22963 Discussions
Weird adaptive gamma in-game. Cannot turn it OFF anymore.
PBism
I have a Dell Laptop with and Intel HD5500 integrated GPU (i5-5300U CPU)
I took screenshots showing a perfect example of what happens in-game:
1. Facing wall not directly in the sun
2. Turning to face a wall that is under the sun:
3. Waiting 10 seconds doing nothing:
As you can see, each time you exit a dark room or go from from the shade a bright environment, you get blinded for a good 5 seconds... because the GPU is still trying to boost light from dark spaces.
I have tried turning on and off every settings and applying them using profiles. What used to be OFF is now ON. I don't know what the name for the parameter is, but I tried them all it seems.
Any help please?
IUman
Hello sqph,
Thank you for joining the Intel communities.
Please post the graphics report, you can see the steps how to get it here:
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
What version of Windows are you using?
Regards!
Ivan
