23272 Discussions
What is the max refresh rate of Intel UHD 730 Graphics at 1440p
Nootje
Nothing special, just that, only that I want to hook it up with USB C 3.2 Gen 2 with display port alt mode. Or hdmi 1.4 but I thought it was worse from what i've seen online
MUC
Honored Contributor I
The processor integrated UHD730 itself features a display engine that provides the following signal interfaces:
HDMI 2.0 TMDS = 4K @ 60 Hz
DisplayPort 1.4a HBR3 = 8K @ 60 Hz
The information for the DisplayPort (and so USB-C) means a bandwidth of 32 Gbps without Display Stream Compression (DSC). This means that 1440p @ 240 Hz RGB 8-bit can be transmitted with 98% bandwidth need. Whether this is actually available to you depends largely on the hardware of the motherboard on which the processor is installed. If you specify the motherboard model or the laptop model, it may be possible to say this more precisely.
Nootje
Hi, the model I use is the Dell Latitude 3440 with an 12th gen I3, more specific the Intel core I3 1215U. Thanks for the help till now!
MUC
Dell Latitude 3440 Setup and Specifications
This port can provide you with the DisplayPort 1.4a HBR3 protocol if you connect a monitor directly with such a cable:
Please note that if you use an USB-C docking station (or a monitor with integrated USB-C hub function), the available video bandwidth may be halved, as the USB protocol then also runs over the same cable. See this.
Nootje
O okay thank you, may sound stupid but can the Intel UHD graphics 730 delier such refresh rate and power at 1440p?
MUC
The display engine of the UHD730 can output high resolutions and refresh rates to watch high-resolution videos and carry out everyday activities on large monitors without straining your eyes.
However, you shouldn't expect miracles from the rendering performance of the graphics overall. Gaming is only covered in the entry-level segment for low levels of detail in undemanding games. It is not suitable for 1440p gaming.
Nootje
O whaha was bot thinking about gaming at all. Just casual use to get things done like work. The reason why I chose 1440p was cause I wanna buy a gaming pc a little from now to later. Thanks for all the help! Can definitie use this information!
