22860 Discussions
What is the max resolution of this card?
NPick1
What's the max output resolution of the Intel G35 Express Chipset Family with the chip type Intel GMA X3500? I have an Intel Core2 Duo E7400 2.80GHz, If that helps. DVI-D and VGA on the back of the computer.
Amy_C_Intel
Hello NickPick528,
In this case you may want to consider the following:
Here is full Datasheet for your Intel® G35 Express Chipset http://www.intel.com/Assets/PDF/datasheet/317607.pdf http://www.intel.com/Assets/PDF/datasheet/317607.pdf
Amy.
Amy_C_Intel
Hello NickPick528,
Amy.
