23282 Discussions
What is the maximum output resolution on Intel HD graphics 620 video card.
MGold6
Hello, I currently own a dell laptop with Intel HD graphics 620 video card. I am in the process of purchasing an external monitor to connect to this laptop. I need to know what is the maximum output resolution on this video card. The monitor I am trying to purchase has resolution 2560 by 1440. So I need to know if with Intel HD graphics 620 card I indeed will be able to see 2560 by 1440 resolution on my new external monitor or will it force me to lower resolution such as 1920 by 1080?Thank you for your help.
Hi Pony333,
I understand you need to know the maximum screen resolution for the Intel® HD graphics 620.Let me help you on this matter.
After checking the graphics controller features I see the maximum screen resolution is 4096*2304 at 60 or 24 Hz. This will depend on the graphics video port.
For multiple Display configuration I recommend checking the following documentation on page 43:
https://www.intel.com/content/www/us/en/processors/core/8th-gen-processor-family-s-platform-datasheet-vol-1.html https://www.intel.com/content/www/us/en/processors/core/8th-gen-processor-family-s-platform-datasheet-vol-1.html
You may need to copy and paste the link in a different window.
Hope it helps.
Allan J.
MGold6
Hello, thank you very much for replying. I tried the link you provided, but unfortunately the page is not loading correctly so I was NOT able to see. Maybe you can just tell me what the maximum resolution for Intel HD graphics 620 is. I have an HDMI port on my video card. Thank you very much for your help.
Hi Pony333,
Sorry to hear you had problems with the link. The maximum screen resolution for the Intel® HD graphics 620 is 4096*2304 via HDMI cable.
Allan J.
MGold6
Thank you so much for your reply. It looks like my laptop is compatible with the monitor I am looking at after all.
ABenh1
I have a similar question?
What is the maximum frequency output available at 1920x1080?
I am using yoga 720 13" lenovo laptop with i7-7500 that includes a intel graphics hd 620.
Can I output 1920x1080@120hz to a monitor?
Hi zarka,
I understand you need information on screen resolution. Please see attached screen for the maximum resolution:
Additionally, this information is available at https://www.intel.com/content/www/us/en/processors/core/8th-gen-processor-family-s-platform-datasheet-vol-1.html https://www.intel.com/content/www/us/en/processors/core/8th-gen-processor-family-s-platform-datasheet-vol-1.html
Allan J
ABenh1
So even if the resolution is lowered to 1920x1080 you can't go higher then 60hz?
Hi zarka,
I will need to confirm this matter but I need your current monitor model number and memory size with the part number. If I need anything else, I will let you know.
Allan J
ABenh1
Hi Allan,
My external monitor is https://www.bhphotovideo.com/bnh/controller/home?O=email&A=details&Q=&sku=1278726&is=REG BenQ ZOWIE XL2411 24" 16:9 144 Hz LCD
My laptop specs:
Yoga 720 13" - Platinum SilverPart No: 80X60067USConfiguration Details● Processor: 7th Generation Intel® Core™ i7-7500U Processor (2.70 GHz 4MB)● Display Type: 13.3" FHD IPS AntiGlare Multitouch (1920x1080) with integrated camera● Memory: 16.0GB DDR4 2133 MHz (Onboard)● Graphics: Intel® HD Graphics 620
Alon
Hi zarka,
Thank you for the information. I am forwarding this information to the appropriate department and I will get back as soon as I get any type of confirmation about this matter.
Allan J.
Hi zarka,
Thank you for your patience.
In order to get 1920 by 1080 at 120Hz you will need to meet the following criteria:
At 1920x1080 @144Hz requires 10.75 Gbps of signal bandwidth.
- At 1920x1080 @120Hz requires 8.96 Gbps of signal bandwidth.
- At 1920x1080 @60Hz requires 4.48 Gbps of signal bandwidth.
- At 1920x1080 @50Hz requires 3.738 Gbps of signal bandwidth.
Additionally, see the picture attached and you will notice the amount of bandwidth required to get proper screen resolution and refresh rate.
Any question, please let me know.
Allan J.
ABenh1
Thanks!
Are the bandwidths mentioned on the post Max. effective bandwidth or Max. specification bandwidth?
Alon
Hi zarka,
Yes, the bandwidth information is available in the picture attached, You will see that this will depend on the video port and the version.
Allan J
