23526 Discussions
When i export an video with an adjustment layer with a basic LUT the exporting gets stucked
YashJ
Whenever i try to export a video with adobe premiere pro 2023 without any kind of adjustment layer on the clip the arc A750 easily exports the project........but when i tried to export the same project with adding an adjustment layer and apply LUT on the adjustment layer and try to export it doesn't work also i am not able to play the video on timeline the playback also gets stucked
Jean_Intel
Hello YashJ,
Thank you for posting in the Intel Communities. We understand that you are experiencing issues when exporting a video adding an adjustment layer, and applying LUT; you also can't play the video on the timeline. To better assist you, we would like to ask for more details about the issue you described:
  • If it is possible, we would like to ask for more details about the step-by-step to reproduce the issue. This may help us to better assist you with your issue and will benefit us in case we need to replicate your problem. A video showing the process of replicating the problem would be ideal.
  • Is there any error message when you try to export the video? If so, provide us with a screenshot of the error message.
  • If any, what troubleshooting steps have you tried to solve this issue?
  • We would like to have more details about your system. Share with us the system reports using the Intel®️ System Support Utility (Intel®️ SSU):
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Best regards
Jean O.
Jean_Intel
Hello YashJ,
We are following up on your thread to see if you have been able to gather the information we requested from you in our previous post. We are more than happy to assist you, and the solicited details will help us to better help you with your issue.
Best regards
Jean O.
Jean_Intel
Hello YashJ,
Since we have not received a response from you, we will proceed to close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards
Jean O.
