23791 Discussions
Which one do i install?
HHelv
Hello intel peps.. i have problem, which one from these two drivers should i install? or maybe i need to stay away from them?
HHelv
Why i want to update? to see if i get some incrase in FPS
CPU
Intel Atom x5 Z8300 @ 1.44GHz 53 °C
Cherry Trail 14nm Technology
RAM
2.00GB DDR3 @ 1599MHz (11-11-11-28)
Motherboard
HP 813E (CHV) 41 °C
Generic PnP Monitor (1280x800@60Hz)
Intel HD Graphics (HP)
Storage
58GB Samsung CGND3R (SD)
Optical Drives
No optical disk drives detected
Audio
Intel SST Audio Device (WDM)
Operating System
Windows 10 Home 64-bit
Computer type: Tablet
Stefan3D
Did you make the screenshots at the same time?
Upper one reads build 4308 installed, lower one build 4444 - that shouldnt happen.
Build 4501 is obviously the newest one, check the release notes if it suites you: https://downloadmirror.intel.com/26228/eng/ReleaseNotes_4501.pdf https://downloadmirror.intel.com/26228/eng/ReleaseNotes_4501.pdf
I recommend to create a https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point "system restore point" before installation, me and other users experienced a black screen after installation.
HHelv
  1. Yup, screenshoots tooks in same time (just edited in one image).
  2. I know it's wierd.. in (Intel graphic properties ->4308). and in (Intel driver update unity -> 4444)..
  3. Thanks for quick response Stefan!
Hello Dedzigs,
With your Intel® Atom™ x5-Z8300 Processor, as part of the Cherry Trail family, you can try to install the version 4501.
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88355 https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88355
This is the best version for you to complete a proper upgrade.
I am looking forward to hearing from you.
Angie
HHelv
Alright, i'll try the 4501.
(though can you help to explain why i did get two of thoese drivers? N-series is for Atom CPU's but for old generations?)
Hello Dedzigs,
In regard to your concern on the "Release Notes" for the .4501 driver it confirms that Cherry Trail it Atom CPUs it is supported:
https://downloadmirror.intel.com/26228/eng/ReleaseNotes_4501.pdf Release Notes Intel® Graphics Driver PV 15.40.28.4501 32bit & 64bit (Page # 2)
Also, Intel® Driver Update Utility will show you all the generic Intel drivers, and your manufacturer(OEM) drivers. The most recommended it is to install the latest OEM drivers, but the latest graphic driver that I have provided to you will be helpful too.
Hope I can hear from you soon.
Angie
HHelv
Update 4051 gives me error, (something about that i already have OEM drivers etc..) quess i could unistall my OEM drivers and then try to install 4051.
Though i think it's better to stay as u say with manufacurer OEM drivers .
Thanks for helps!
Hello Dedzigs,
I am glad to know that the information provided was able to solve your concern.
For any further question do not hesitate to use our /community/tech Intel Communities, we will be more than happy to assist you.
Angie
