23106 Discussions
Why DH77KC and DB75 EN Motherboard cannot Run Gainward Gforce GT630 2Gb DDR3 Graphics card
MY Mother board is DH77 Kc And My Friend's is DB75 EN
The Following are the machine spec
Mine Is :-
MOBO DH77Kc
Processor = Core I7 3770
Psu is 750 Watt
Ram Corsier Value Select 4 Gbx2
Hdd 1Tb Toshiba.
Os Windows Ultimate 32 bit (sp1)
Friend's is
MOMO DB75 EN
Processor Core I5 3570
Psu 800 Watt
Hdd seagate 1 Tb
OS Windows ultimate 64 bit
Machine only shows the splash screen of INTEL Machine running in standstill even keyboard not working to allow to enter bios setup
This same GFX card when I tested in intel DH61 HO aswell as Dh61 WW works fine in single shoot
please help me to resolve this problem on 'H7' series of board otherwise i will loose that purchasing price amount.
Thanking you
ASIS
Silvia_L_Intel1
Hello Asis, the behavior you are experiencing looks like a compatibility issue.
Some recommendations we can give you could be:
Thank you for your response
I tried the steps you described in the last three points, but once I have a very bad experience to update BIOS with my Intel 845 GVSR , after updating that with my Novice skill I damaged that fine working MOBO Permanently.
So i Want a Link that actually teaches the Bios Up gradation procedure step by step without damaging the motherboard.
If you have so plz, guide me to that link
Thank you again for giving advice
Asis Ghosh
Silvia_L_Intel1
The following link will give all the instructions you need to follow. http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS Update Instructions
Remember that motherboards are electronic devices and they can fault at any time.
So please try to follow the recommendations I gave you on post # 1
