23758 Discussions
Why does Intel D&SA think I have a Radeon?
Razer Blade Pro FHD
i7-7700hq
intel hd 630
nvidia GTX 1060
I had an issue when the switch to the D&SA went up a few weeks ago and couldn't get anything to work. I finally got the download and my graphics update, and now it keeps telling me I have an update avaiable. The first I downloaded it without thinking twice as I trust intel. Then it said it can not find the driver so the install has stopped. Then when looking at the update requirements and everything else it says that I have a RADEON RX VEGA M graphics, listed below that is my NVIDIA GEFORCE GTX 1060, What am I missing? Or did Intel mess something up? I have manually installed the newest version with no luck, i have now switched back to the previous version with no luck. I wouldn't have even noticed if my Diablo3 wasn't crashing every few hours and telling NO GRAPHICS CARD CAN BE FOUND ON DEVICE and then theres a caution sign next to the intel hd 630 in my device management, and restarting the computer usually fixes it. HELP!!!!!!
Hello samuraistrong,
I understand that you are having problems with the graphics adapters after the update with Intel ® Driver & Support Assistant.
Regarding this, to better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
Also, if possible, please provide me with screenshots of the device manager showing the caution sign and the graphics adapters. How long ago was the Intel ® Driver & Support Assistant installed?
David V
System Information
Time of this report: 6/19/2018, 21:45:44
Machine name: LAPTOP-4AUL23EV
Machine Id: {AEFABD8B-3468-4959-9392-7D3DC405CD7F}
Operating System: Windows 10 Home 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
Language: English (Regional Setting: English)
System Manufacturer: Razer
System Model: Blade Pro
BIOS: 2.02 (type: UEFI)
Processor: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz (8 CPUs), ~2.8GHz
Memory: 16384MB RAM
Available OS Memory: 16280MB RAM
Page File: 7056MB used, 12039MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
DxDiag Version: 10.00.17134.0001 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 630
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_591B&SUBSYS_67581A58&REV_04
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8268 MB
Dedicated Memory: 128 MB
Shared Memory: 8140 MB
Current Mode: 1920 x 1080 (32 bit) (120Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.638195,0.337414), Green(0.322766,0.610852), Blue(0.151867,0.048352), White Point(0.313977,0.329602)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO169D
Native Mode: 1920 x 1080(p) (120.150Hz)
Output Type: Internal
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igd12umd64.dll
Driver File Version: 24.20.0100.6094 (English)
Driver Version: 24.20.100.6094
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.4
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:False
Driver Attributes: Final Retail
Driver Date/Size: 5/15/2018 7:00:00 PM, 2037808 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-1A5B-11CF-266E-3C47BFC2D535}
Vendor ID: 0x8086
Device ID: 0x591B
SubSys ID: 0x67581A58
Revision ID: 0x0004
Driver Strong Name: oem59.inf:5f63e53499417f2d:iKBLD_w10_DS:24.20.100.6094:pci\ven_8086&dev_591b
Rank Of Driver: 00D12001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeVP8_VLD DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Bac...
had another crash.
System Information
Time of this report: 6/20/2018, 01:33:44
Memory: 16384MB RAM
Page File: 6515MB used, 12580MB available
User DPI Setting: 120 DPI (125 percent)
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Notes
Display Tab 1: There is a problem with Intel(R) HD Graphics 630 device. For more information, search for 'graphics device driver error code 43'
Display Devices
Card name: Microsoft Basic Display Driver
DAC type: Internal
Device Type: Display-Only Device
Device Status: 01802400 [DN_HAS_PROBLEM|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: 0000002B [CM_PROB_FAILED_POST_START]
Display Memory: 8140 MB
Dedicated Memory: 0 MB
Current Mode: 1920 x 1080 (32 bit) (64Hz)
Color Primaries: Red(0.640148,0.330578), Green(0.300305,0.600109), Blue(0.149914,0.060070), White Point(0.313000,0.329602)
Monitor Id: AUO169D
Output Type: Other
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9929e26743d53831\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9929e26743d53831\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9929e26743d53831\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_9929e26743d53831\igd12umd64.dll
Driver File Version: 24.20.0100.6136 (English)
Driver Version: 24.20.100.6136
DDI Version: 12
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Not Supported
Virtualization: Not Supported
Catalog Attributes: N/A
Driver Date/Size: 5/23/2018 7:00:00 PM, 2035176 bytes
WHQL Logo'd: Yes
Device Identifier: {D7B71AF4-43CC-11CF-C063-EE62AFC2C735}
Vendor ID: 0x1414
Device ID: 0x008C
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: oem61.inf:5f63e53499417f2d:iKBLD_w10_DS:24.20.100.6136:pci\ven_8086&dev_591b
Video Accel:
DXVA2 Modes: Unknown
Deinterlace Caps: {00000000-0000-0000-0000-000000000000}: Format(In/Out)=(YUY2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{00000000-0000-0000-0000-000000000000}: Format(In/Ou...
Thank you for your response and the information.
It seems like there is a problem with the integrated graphics. Regarding the Intel ® Driver & Support Assistant I would recommend you to uninstall it and then re-install it from our support site again, you can do so by downloading it from the link below:
https://www.intel.com/content/www/us/en/support/detect.html https://www.intel.com/content/www/us/en/support/detect.html
Make sure to first completely remove it from your system before attempting the re-installation.
Also, regarding the problem you are having with the integrated graphics, I want you to download the ".zip" file:
https://downloadcenter.intel.com/download/27847/Graphics-Intel-Graphics-Driver-for-Windows-10?product=98909 https://downloadcenter.intel.com/download/27847/Graphics-Intel-Graphics-Driver-for-Windows-10?product=98909
Once the file is downloaded, please follow the steps below in order to manually install the driver:
1 - Unzip the file to a designated location or folder.
2 - Right-click Windows Start icon and open Device Manager.
3 - Click Yes when prompted for permission from User Account Control.
4 - Expand the Display adapters section.
5 - Right-click the Intel® graphics entry and select Update Driver Software.
6 - Click "Browse my computer for driver software".
7 - Click "Let me pick from a list of device drivers on my computer".
8 - Click "Have Disk".
9 - Click "Browse".
10 - Access the designated location or folder, and access a folder called "Graphics".
11 - Select the .INF file (Setup information).
12 - Click Open, then click OK, and finally click Next. Drivers are now being installed.
13 - Reboot your computer
Once this has been done, please let me know the outcome with how it shows under device manager.
I hope this helps.
David V
I upgraded using the "igdlh64" file because it was that or "IntcDAud"
Thank you for your response.
Were you able to re-install the Intel ® Driver & Support Assistant?
Remember that this step is important so we can check if the software still thinks your system has radeon* graphics.
Let me know please.
David V
MBevi
The Intel driver & support assistant suggests I should install the radon driver, though I have an HD graphics 630. I was able to manually update my driver but I though I should give some extra feedback if it can help others. My intel d&s assistant is updated and so is my windows version.
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
