23776 Discussions
Windows 10 Graphics Driver Install issue
KMcBr
So Ive been experiencing the, what seems to be common, graphics driver crashing at random intervals on my Windows 10 Lenovo Flex 2-15 intel i5 4210u hd4400 Laptop.
I'm using the default Windows 10 driver (Driver Version: 10.18.15.4279). I thought maybe I would try to go back to the Lenovo driver but I get an error saying that its not compatible ??? Do I need to uninstall Driver Version: 10.18.15.4279 before installing Lenovo's? If I do revert what will stop Windows from auto updating?
Thank you.
Amy_C_Intel
Hello, Ebojager:
Try to follow these instructions https://support.lenovo.com/cr/es/documents/ht074189 How to install drivers manually - Lenovo Support (US). If you are not able to install Lenovo's driver I would recommend getting in contact with them since it might be possible that the installation requires a different procedure.
From our end you can give it a try with the Beta driver https://downloadcenter.intel.com/download/25749/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?v=t Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40] and if you want to give it a try follow these instructions http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &...
Amy_C_Intel
Hello, Ebojager:
KMcBr
Thank you. I got the same error trying to install the beta driver before hearing from you, until I found out how to install them manually. That worked. I have not tried the same procedure with the Lenovo driver 15.40.3.64.4248 yet as, I'm testing out the current driver 20.19.15.4331. My old driver was 10.18.15.4279. I don't know where 20.19.15.4331 came from, but it was installed after I uninstalled the beta driver to do a reinstall cause my second monitor came on during the installation and i felt better if I reinstalled without that happening. I was offline during this installation and have used Microsoft troubleshooter to hide updates for intel graphics driver. Things seem good sofar with this driver 20.19.15.4331. I will try the beta driver if I experience the driver crash anymore.
Amy_C_Intel
I'm glad to hear that this method worked for you.
If you need further assistance let us know.
KMcBr
Just a quick follow up, not sure where to put it... since updating to the 20.19.15.4331 graphics driver I have not experienced the Display Driver crash I was experiencing with 10.18.15.4279. <<< I think this is what Windows 10 installed.
Amy_C_Intel
Thank you for your feedback.
