告知
23492 ディスカッション
Windows 10 Ver 1607 64 bit driver for intel HD graphics 3000
VVive3
ビギナー
30,665件の閲覧回数
Hi All
I have a HP dv6-6016tx laptop with 2 display adapters in the display manager:
  1. AMD Radeon HD 7400M
  2. Intel HD Graphics 3000
When I first updated to windows 10, the screen would go blank for about 45 seconds while starting up and resuming from sleep. I fixed this by setting the EnableULPS registry key to 0. I think this just disabled the Intel Driver.
When I updated to Windows 10 ver 1607, I found that AMD Catalyst had been uninstalled (possibly not compatible) and the blank screen problem returned.
Now when I open device manager the driver details of Intel HD Graphics 3000 are:
Driver Version: 9.17.10.4229 Dated 05/27/15 Provided By Intel.
The driver on Intel website is for Windows 7 & 8 Only
Date: 05-Jun-2015 Version: 15.28.24.64.4229 (Latest) OS: Windows 7, 64-bit*, Windows 8, 64-bit*
I want to know whether I can install the above driver on Windows 10 ver 1607 (64 bit) Build: 14393.321 and whether the blank screen problem will go away.
Thanks is advance for your reply.
VS
0 件の賞賛
9 返答(返信)
AlHill
スーパーユーザー
28,375件の閲覧回数
HD Graphics 3000 is not supported on Windows 10:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
Doc
従業員
28,375件の閲覧回数
Hello VS228,
Correct, Intel HD Graphics 3000 is not supported for Windows 10*
The driver 4229 is the latest available for Windows 8.1*
You could disable each of the graphics adapters in the device manager to find out which works the best.
I apologize for any issue this may have caused!
Esteban C
FMart22
ビギナー
28,375件の閲覧回数
Hi VS228, try this drivers Catalyst 16.2.1 UnifL: http://leshcatlabs.net/forums/showthread.php?tid=1176 http://leshcatlabs.net/forums/showthread.php?tid=1176
The drivers are up to date to May 30, 2016 - Intel v.10.17.10.4229, AMD v.16.301.1901.0
I use them on my laptop with Windows 10 Pro x64 v1607 14393.447, AMD Radeon HD 6700M and Intel HD Graphics 3000 and works fine.
従業員
28,375件の閲覧回数
Thank you for the information provided, Francisco77
Please note these are not official drivers and Intel does not fully recommend using them, VS228 .
Esteban C
FMart22
ビギナー
28,375件の閲覧回数
Hi Esteban, I understand, but Intel does not provide support for dual graphics card, only the manufacturer, like HP in this case.
So, my recommendation is based in my experience because I had a similar problem and these drivers worked for me on Windows 10.
従業員
28,375件の閲覧回数
Yes, I understand your point, Francisco77
I just wanted to make things related to support clear in order to avoid misunderstandings 🙂
In case you require any further questions answered in the future, feel free to reach us here or any other support platform.
Hope you guys have a great week!
Esteban C
VVive3
ビギナー
28,375件の閲覧回数
Is it compatible with AMD Radeon HD 7400M?
Installation instructions would be greatly appreciated.
Thanks and regards
VS
FMart22
ビギナー
28,375件の閲覧回数
UnifL stands for `Unified Leshcat Drivers`.
Those drivers are based on latest AMD + Intel Drivers and aimed to support laptops (and Desktops too) powered with:
• AMD 5xxx/6xxx/7xxx/8xxx/Rxxx Series
• Intel HD/HD2000/HD2500/HD3000/HD4000/Iris/Haswell/Broadwell CPU Embedded Graphics
UnifL drivers are designed and tested on x64 versions of Windows 7/Windows 8.1/Windows 10,
however it should work on Server Editions (i.e: Windows Server 2008) as well.
Unified Leshcat Driver Manual v1.5.2 11.01.2016: http://leshcatlabs.net/manual_chm/ http://leshcatlabs.net/manual_chm/
I hope it helps.
Francisco77
従業員
28,375件の閲覧回数
Thanks for the information shared, Francisco77
Esteban C
返信
