I just installed Windows 8 Pro on my HP Envy 14 and now the HDMI output will not work. Any ideas on how to fix this?
Hi gavin.j.tu,
Was the HDMI port working fine with another operating system or driver?
Would you please POST the Graphics Diagnostic Report? This link will help you to generate that report http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Thanks!
Intel® HD Graphics (Core i5)
Report Date: 1/23/2013
Report Time[hr:mm:ss]: 15:10:0
Driver Version: 8.15.10.2858
Operating System: (6.2.9200)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 3893 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 93 MB
Processor: Intel64 Family 6 Model 37 Stepping 5
Processor Speed: 2527 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 2056.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 12.60 inches
Vertical: 07.09 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 B6 02 00 00 00 00
00 14 01 03 80 20 12 78 0A 1F 65 9E 5F 58 9C 27
1B 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 12 1B 56 78 50 00 0E 30 20 20
24 00 41 B5 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 35 57 48 31 2D 54 4C 42 31 00 62
* Other names and brands are the property of their respective owners. *
Hi gavin.j.tu,
Thanks for the graphics diagnostic report.
I can see you have a processor with Intel HD Graphics. What happens is that the graphics controller is not compatible with Windows 8. The driver you have currently installed is a generic driver and we cannot guarantee all of the graphics features will work fine. I recommend reinstalling the operating system that came with your computer since that is the operating system that has been validated by HP to work with your specific computer model.
Thanks!
