23795 Discussions
Windows 8 black screen at start up
Hello I am having a issue with my onboard Intel graphics and Windows 8, when i install the HD graphics driver and restart my screen is working fine upto the point Windows loads the drivers so i get the windows logo and then nothing no log in screen nothing. I know the computer is on and working as i can connect remotely to it and it works fine.
System Specs:
Computer Manufacturer Gigabyte Technology Co., Ltd.Computer Model Z68AP-D3Operating System (O/S) Microsoft Windows 8Operating System Build (O/S)(build 9200), 64-bitOperating System (version) 6.2.9200ManufacturerIntelModel http://www.intel.com/p/en_US/support/ Intel(R) Core(TM) i3-2100 CPU @ 3.10GHzIntel Processor analysis toolshttp://www.intel.com/support/processors/sb/CS-015477.htm Intel Processor analysis tools CPU Speed3.1 GHzLink to Processor Specificationhttp://ark.intel.com/ Link to Processor SpecificationCPU RevisionCPU Type00CPU Family06CPU Model2ACPU Stepping7
DArce
Valued Contributor III
Could you please specify if this happens with the driver provided by your motherboard manufacturer or just with the generic drivers in our site?
Please, also post the exact driver versions that you have tested with and the BIOS version installed.
Hello Diego,
The bios version is F8 which is the most recent release for the revision 1 board, in regards to drivers I have tried the driver from Gigabyte version 15.28.4.2843 I have also tried the driver from Intel version 15.28.12.64.2932 both have the same effect black screen after windows logo.
I have a LG monitor L246WH connected via HDMI works fine when i disable Intel HD graphics through device manager but if i do that the sleep function stops working so would like to get my Win 8 ready board and chipset working correctly.
DArce
Could you please confirm if the connection is directly from the computer to the TV? Or there is an AVR receiver, adapter, converter or similar device being used in between?
Have you tested another HDMI cable?
Could you confirm if the cable supports HDMI 1.4?
