23539 Discussions
Windows HDMI Audio Driver - WASAPI PCM 4.0 FL+FR+SL+SR layout support
Krobaruk
Is there any plan to improve the multichannel PCM support in the Intel Windows HDMI audio driver?
For 4 PCM channels, channel mapping support seems to be as follows:
Quad (FL + FR + SBL +SBR) - Supported
3.1 (FL +FR + C + LFE) - Supported
4.0 (FL +FR + SL +SR) - Unsupported.
Support for 4.0 is becoming more important as increasingly Quad format is not supported by AV receivers.
PCM channel mapping support is likely to be included in the next major release of Kodi too so this will become more noticeable:
PCM 3.0 Output from HDMI (kodi.tv)
Tested on Intel 8th Gen Supermicro C246 motherboard (HDMI 1.4 output) and Dell laptop with 10th gen Intel CPU (HDMI 2.0 output) with the same result (WASAPI reports the channel layout is not supported). Other users have confirmed the same issue so does not seem to be hardware dependant. The layout is supported fine with Intel HDMI output in Linux so seems to be a driver/software problem.
David_G_Intel
Hello Krobaruk
Thank you for posting on the Intel️® communities. Please specify which Intel product you own or for which product you are seeking information.
David G
Krobaruk
Two Intel based products I own are affected:
Dell Precision 3541 with 10th Gen I5
Intel 8th Gen I3 on a Supermicro X11SCA
The same issue exists for other hardware which uses the Intel HDMI audio driver as well.
Another possibility is if Intel mapped Quad to FL+FR+SL+SR in the HDMI audio info frame compatibility would greatly improve.
David_G_Intel
Thank you for the update, we need the model of the processors to continue with this request. Please also share the Intel® System Support Utility (Intel® SSU) results:
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
David_G_Intel
David G.
David_G_Intel
David G.
