23523 Discussions
Xeon Processor E3-1285 v3, Graphics P4700, 4k support?
Clay_D_Intel
I am having trouble getting the 4K resolution working on Xeon E3-1285 v3, Graphics P4700, via the display port.
I have re-installed the latest graphics driver but no luck. Any thoughts on how to resolve?
Thanks! --Clay
Here are some of the configuration to help:
Server board http://ark.intel.com/products/71387/Intel-Server-Board-S1200V3RPM http://ark.intel.com/products/71387/Intel-Server-Board-S1200V3RPM
CPU http://ark.intel.com/products/75465/Intel-Xeon-Processor-E3-1285-v3-8M-Cache-3_60-GHz http://ark.intel.com/products/75465/Intel-Xeon-Processor-E3-1285-v3-8M-Cache-3_60-GHz
OS Windows 8.1, 64 bit, Enterprise
Monitor Samsung, U28D590D, http://www.samsung.com/us/computer/monitors/LU28D590DS/ZA http://www.samsung.com/us/computer/monitors/LU28D590DS/ZA
Connection Display Port to Display Port
And a similar thread:
https://communities.intel.com/thread/52247 https://communities.intel.com/thread/52247
Clay_D_Intel
Also, below is the graphics summary report:
Intel(R) HD Graphics P4600
Report Date: Wednesday, December 31, 2014
Report Time [hh:mm:ss]: 6:31:21 PM
Operating System: Windows* 8.1 Enterprise (6.3.9600)
Default Language: English (United States)
Physical Memory: 32383 MB
Video BIOS: 2170.0
Processor: Intel(R) Xeon(R) CPU E3-1286 v3 @ 3.70GHz
Processor Speed: 3691 MHz
Processor Graphics in Use: Intel(R) HD Graphics P4600
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 11.2
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Device Type: DisplayPort
Maximum Image Size
Horizontal Size: 24.02 inches
Vertical Size: 13.78 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (70p Hz)
1024 x 768 (75p Hz)
1024 x 768 (60p Hz)
1152 x 870 (75p Hz)
1152 x 864 (75p Hz)
1280 x 1024 (75p Hz)
1280 x 800 (60p Hz)
1280 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1440 x 900 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
2560 x 1440 (60p Hz)
3840 x 2160 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 2D 80 0B 00 00 00 00
34 17 01 04 B5 3D 23 78 3A 5F B1 A2 57 4F A2 28
0F 50 54 BF EF 80 71 4F 81 00 81 C0 81 80 A9 C0
B3 00 95 00 01 01 4D D0 00 A0 F0 70 3E 80 30 20
35 00 5F 59 21 00 00 1A 56 5E 00 A0 A0 A0 29 50
30 20 35 00 5F 59 21 00 00 1A 00 00 00 FD 00 38
4B 1E 86 36 00 0A 20 20 20 20 20 20 00 00 00 FC
00 55 32 38 44 35 39 30 0A 20 20 20 20 20 01 6E
02 03 0E F0 41 10 23 09 07 07 83 01 00 00 02 3A
80 18 71 38 2D 40 58 2C 45 00 5F 59 21 00 00 1E
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44
* Other names and brands are the property of their respective owners.
Jose_H_Intel1
In this case the driver for Intel® HD Graphics P4700 only comes from the system manufacturer.
Please contact them for further assistance.
Clay_D_Intel
Joe - thanks for the reply.
Interesting since this is an Intel design + mfg board (Intel, DCG, PCSD/EPSD).
I will see if I can send you a PM with some additional info.
Clay_D_Intel
In case other folks might have this issue...
Some progress – I am able to get 4k, 30hz working via a DP -> HDMI cable to the monitor.
But I still can't get the 4k, 60hz working via DP -> DP cable.
Jose_H_Intel1
I am sorry, I missed that part.
I am glad you got it working.
You can also post in
ROBERT_U_Intel
Hi Clay
Are you using the 15.36.14.4080 graphics driver here? https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24596&lang=eng&ProdId=3719 Intel® Download Center
Robert
