22923 Discussions
Your computer does not meet the minimum requirement for installing the software.
JRodi
I started having problems with my graphics driver so I decided to uninstall it from Device Manager. Then I decided to reinstall my driver by going to to the intel site. Since I have an Intel HD 2000 I downloaded it from here. https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23764&lang=eng&ProdId=3319 Intel HD Graphics 2000/3000 Download
I went through the setup process and when it was installing I got an error message saying "Your computer does not meet the minimum requirement for installing the software". Why does it say that? I have an Intel HD 2000 Graphics driver and I installed the right download! Also when I go to device manager and see the adapters and all I see is Video Controller (VGA Compatible).
Here is my system info.
OS NameMicrosoft Windows 7 Home PremiumVersion6.1.7601 Service Pack 1 Build 7601Other OS DescriptionNot AvailableOS ManufacturerMicrosoft CorporationSystem NameRODICA-PCSystem ManufacturerLENOVOSystem ModelLenovo H420System Typex64-based PCProcessorIntel(R) Core(TM) i3-2100 CPU @ 3.10GHz, 3100 Mhz, 2 Core(s), 4 Logical Processor(s)BIOS Version/DateLENOVO DPKT15A, 2/25/2011SMBIOS Version2.6Windows DirectoryC:\windowsSystem DirectoryC:\windows\system32Boot Device\Device\HarddiskVolume1LocaleUnited StatesHardware Abstraction LayerVersion = "6.1.7601.17514"User NameRODICA-PC\RODICATime ZoneCentral Daylight TimeInstalled Physical Memory (RAM)6.00 GBTotal Physical Memory<td style="padding-right: 4...
Kevin_M_Intel
Hi CoreTech,
I am sorry you are having problems installing the driver but let me help you finding the solution for this.
It is important to mention that the reason why you are getting this message during the installation of our driver is that the driver is standard software for your OEM computer. What I mean to say is that we as Intel® provide the hardware to Computer Manufactures and they will design and create their systems with special configurations so you may find problems installing our driver.
However, there are some troubleshooting steps you can try to solve the issue. Please download the driver for your controller at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23764&lang=eng&ProdId=3319 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23764&lang=eng&ProdId=3319
Check the steps mentioned here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Kevin M
Kevin_M_Intel
Hi CoreTech,
Kevin M
JRodi
Okay, so I followed the steps and uninstalled the driver and reinstalled it. The installation finished and made me restart my computer. After my computer restarted it said driver installing at the right hand corner. I looked and the driver was Video Controller (VGA Compatible). It also failed to install. Any feedback on what I should do?
Kevin_M_Intel
Hi CoreTech,
I am sorry to hear you are still having problems. At this point if you have done the troubleshooting steps mentioned before the best option at this point is for you to contact the Computer Manufacture and get their special drivers for your computer.
Kevin M
АТолм
Kevin,
Help please!
I have installed Windows 7 Ultimate 32 on my new Asus X553M and I have successfully installed all drivers except Intel HD graphics.
I am getting "The computer does not meet the minimum requirement"
I am downloading old and new drivers from Intel - does not work
I am downloading zipped and exe versions of driver - does not work
I am downloading Intel® Driver Update Utility. It detects the video but can not install the driver.
I am trying to update the driver through "Update driver" system option - does not work.
What am I doing wrong?
System Information
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: X553MA
BIOS: BIOS Date: 06/27/14 12:16:09 Ver: 05.06.05
Processor: Intel(R) Pentium(R) CPU N3530 @ 2.16GHz (4 CPUs), ~2.2GHz
Memory: 4096MB RAM
Available OS Memory: 2958MB RAM
Page File: 3287MB used, 2627MB available
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: (Standard display types)
Chip type: Intel(R) VLV Mobile/Desktop Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0F31&SUBSYS_161D1043&REV_0E
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1366 x 768 (32 bit) (1Hz)
Monitor Name: Generic PnP Monitor
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (Russian)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 02:25:51, 10752 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4C71-11CF-F233-AD2BA0C2CB35}
Vendor ID: 0x8086
Device ID: 0x0F31
SubSys ID: 0x161D1043
Revision ID: 0x000E
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Kevin_M_Intel
Hello AlexTol,
I noticed you opened another thread so we are going to continue from there.
This is the link:
/thread/57424 https://communities.intel.com/thread/57424
Kevin M
fjand
hello kevin im having the same error message can you help me ? i need graphics driver for my windows server 2012
thats my system info
System Information
Time of this report: 3/15/2015, 22:48:54
Machine name: WIN-SIGPA2LL0GI
Operating System: Windows Server 2012 R2 Standard 64-bit (6.3, Build 9600) (9600.winblue_gdr.140221-1952)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N5040
BIOS: BIOS Date: 09/23/09 11:58:43 Ver: 08.00.10
Processor: Intel(R) Pentium(R) CPU P6200 @ 2.13GHz (2 CPUs), ~2.1GHz
Memory: 2048MB RAM
Available OS Memory: 1910MB RAM
Page File: 683MB used, 2379MB available
Windows Dir: G:\Windows
DxDiag Version: 6.03.9600.16384 64bit Unicode
Display Devices
Card name: Microsoft Basic Display Driver
Manufacturer:
Chip type:
DAC type:
Device Type: Display-Only Device
Device Key: Enum\ROOT\BASICDISPLAY
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1024 x 768 (32 bit) (64Hz)
Monitor Model: unknown
Monitor Id: LGD02DC
Native Mode: 1366 x 768(p) (59.992Hz)
Kevin_M_Intel
Hello faresjandali,
Please note that the drivers we currently have are Windows Operating System for desktop platforms so we do not have drivers for Server versions.
My recommendation is to contact your Computer Manufacture and request the driver from their side.
Kevin M
