23527 Discussions
a770 high power consumption in linux even not plugin display
simon007
i have enabled aspm in bios. when use windows, the power can be lower to 8w.
but when use linux, promox 8.1 with kernel 6.8.12, the a770 power consumption is 36~40 even not plugin display.
how can make it run lower power when idle, thanks
root@pve:~# dmesg | grep ASPM
[ 0.544767] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.563068] pci 0000:10:00.0: ASPM: overriding L1 acceptable latency from 0x0 to 0x7
root@pve:~# lspci -vv | awk '/ASPM/{print $0}' RS= | grep --color -P '(^[a-z0-9:.]+|ASPM )'
10:00.0 VGA compatible controller: Intel Corporation DG2 [Arc A770] (rev 08) (prog-if 00 [VGA controller])
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes, Disabled- CommClk+
simon007
i found ubuntu24.04 works fine with kernel Linux ubuntu 6.8.0-41-generic #41-Ubuntu. so how can i to figure out why
simon007
every goes well after refresh install proxmox
RandyT_Intel
Hello simon007,
Thank you for reaching out to us regarding the issue you’re experiencing with your system. While ASPM is enabled, the effectiveness can vary based on the operating system’s implementation and driver support. The logs you provided show that ASPM is enabled, but the actual power savings might not be fully realized due to other factors. Linux drivers, especially for newer hardware like the Intel Arc A770, might not be as optimized as their Windows counterparts. This can lead to higher power consumption. In addition, different Linux distributions and kernel versions can have varying levels of support and optimization for power management features.
To better assist you, I need to gather some additional information. Could you please answer the following questions?
  • Can you please run the System Support Utility (SSU) and share the logs with me?
  • Are you using the latest drivers for your Intel Arc A770 on both Windows and Linux? Sometimes, driver optimizations can significantly impact power management.
  • Have you checked the power management settings in your Linux environment? Different distributions and kernels might handle power management differently.
  • Besides enabling ASPM, are there any other power-saving features in the BIOS that might be enabled or disabled?
  • Are there any background processes or services running on Linux that might be preventing the GPU from entering a low-power state such as virtual machines (VMs), containers and software-defined storage (SDS) in a single, unified interface?
Providing this information will help me diagnose the system more accurately and check for available solutions. Thank you for your cooperation, and I look forward to your response.
Randy T.
simon007
thank you for reply.
after refresh install proxmox, the aspm works fine. but still some problem with gpu passthrough.
  • there are reset bug, i must clean reset method before passthrough. otherwise the CPU will hang up and eventually the entire system will restart.
echo > /sys/bus/pci/devices/0000:10:00.0/reset_method
echo > /sys/bus/pci/devices/0000:11:00.0/reset_method
  • the aspm will not work after rebind to host,power consumption between 37~40W. i tried the fllowing
1.
# use driverctl
/usr/sbin/driverctl -v --nosave set-override {device_id} vfio-pci
/usr/sbin/driverctl -v --nosave unset-override {device_id}
2.
# when bind
echo 1 > /sys/bus/pci/devices/{device_id}/remove
echo 1 >  /sys/bus/pci/rescan
sleep 1
echo > /sys/bus/pci/devices/{device_id}/reset_method
echo {device_id} > /sys/bus/pci/devices/{device_id}/driver/unbind
sleep 2
echo {device_id} > /sys/bus/pci/drivers/vfio-pci/bind
# when back to host bind to i915
sleep 1
sleep 1
sleep 1
echo {device_id} > /sys/bus/pci/drivers/i915/bind
3.
# reload i915
modprobe -r i915
modprobe i915
ssu log in attachment
simon007
there are some log in dmesg, after reoot and long running.
root@pve:~# uptime
 12:20:47 up 10:18,  2 users,  load average: 3.49, 2.27, 1.65
[36170.762595] i915 0000:10:00.0: Use count on power well always-on is already zero
[36170.762658] WARNING: CPU: 7 PID: 1908439 at drivers/gpu/drm/i915/display/intel_display_power_well.c:130 intel_power_well_put+0xa1/0xb0 [i915]
[36170.763295] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36170.763510]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36170.763728] CPU: 7 PID: 1908439 Comm: kworker/u66:3 Tainted: P        W  O       6.8.12-2-pve #1
[36170.763747] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36170.763761] Workqueue: events_unbound intel_display_power_put_async_work [i915]
[36170.764332] RIP: 0010:intel_power_well_put+0xa1/0xb0 [i915]
[36170.764865] Code: 40 48 8d 04 c1 4c 8b 30 4d 85 ed 75 03 4c 8b 2f e8 f4 e8 0f c4 4c 89 f1 4c 89 ea 48 c7 c7 b0 16 c5 c1 48 89 c6 e8 2f eb 70 c3 <0f> 0b 8b 43 18 e9 72 ff ff ff 0f 1f 44 00 00 90 90 90 90 90 90 90
[36170.764887] RSP: 0018:ffffbf489815fd30 EFLAGS: 00010246
[36170.764901] RAX: 0000000000000000 RBX: ffff9f7151df2800 RCX: 0000000000000000
[36170.764913] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36170.764923] RBP: ffffbf489815fd50 R08: 0000000000000000 R09: 0000000000000000
[36170.764933] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f7157274000
[36170.764942] R13: ffff9f7142558a20 R14: ffffffffc1c7d836 R15: ffffffffffffffff
[36170.764953] FS:  0000000000000000(0000) GS:ffff9f803e580000(0000) knlGS:0000000000000000
[36170.764967] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36170.764978] CR2: 00007969844c0520 CR3: 00000001284c6000 CR4: 0000000000f50ef0
[36170.764991] PKRU: 55555554
[36170.764998] Call Trace:
[36170.765005]  <TASK>
[36170.765015]  ? show_regs+0x6d/0x80
[36170.765037]  ? __warn+0x89/0x160
[36170.765050]  ? intel_power_well_put+0xa1/0xb0 [i915]
[36170.765550]  ? report_bug+0x17e/0x1b0
[36170.765567]  ? handle_bug+0x46/0x90
[36170.765579]  ? exc_invalid_op+0x18/0x80
[36170.765591]  ? asm_exc_invalid_op+0x1b/0x20
[36170.765612]  ? intel_power_well_put+0xa1/0xb0 [i915]
[36170.766116]  __intel_display_power_put_domain+0xd9/0x1b0 [i915]
[36170.766620]  ? __intel_runtime_pm_get+0x32/0xb0 [i915]
[36170.767016]  release_async_put_domains+0x83/0x120 [i915]
[36170.767509]  ? __intel_runtime_pm_get+0x32/0xb0 [i915]
[36170.767903]  intel_display_power_put_async_work+0xa0/0x160 [i915]
[36170.768386]  process_one_work+0x16a/0x350
[36170.768405]  worker_thread+0x306/0x440
[36170.768422]  ? __pfx_worker_thread+0x10/0x10
[36170.768439]  kthread+0xef/0x120
[36170.768465]  ? __pfx_kthread+0x10/0x10
[36170.768479]  ret_from_fork+0x44/0x70
[36170.768495]  ? __pfx_kthread+0x10/0x10
[36170.768508]  ret_from_fork_asm+0x1b/0x30
[36170.768525]  </TASK>
[36170.768532] ---[ end trace 0000000000000000 ]---
when  i start to passthrough gpu to vm
[36974.356546] i915 0000:10:00.0: All device reset methods disabled by user
[36975.374632] ------------[ cut here ]------------
[36975.374637] i915 0000:10:00.0: drm_WARN_ON(!timeout_expected)
[36975.374671] WARNING: CPU: 21 PID: 1967588 at drivers/gpu/drm/i915/display/intel_display_power_well.c:283 hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.374800] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36975.374856]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36975.374910] CPU: 21 PID: 1967588 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[36975.374914] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36975.374917] RIP: 0010:hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.375018] Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 a1 05 10 c4 48 c7 c1 88 14 c5 c1 48 89 da 48 c7 c7 40 d8 c7 c1 48 89 c6 e8 d8 07 71 c3 <0f> 0b e9 74 ff ff ff 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90
[36975.375022] RSP: 0018:ffffbf48909e7980 EFLAGS: 00010246
[36975.375025] RAX: 0000000000000000 RBX: ffff9f7142558a20 RCX: 0000000000000000
[36975.375028] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36975.375030] RBP: ffffbf48909e79a8 R08: 0000000000000000 R09: 0000000000000000
[36975.375031] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f7157274000
[36975.375033] R13: ffff9f7151df28a0 R14: ffffffffc1bec850 R15: 0000000000045404
[36975.375035] FS:  00007fb30f57c740(0000) GS:ffff9f803ec80000(0000) knlGS:0000000000000000
[36975.375038] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36975.375040] CR2: 0000608c399409cc CR3: 00000006540bc000 CR4: 0000000000f50ef0
[36975.375042] PKRU: 55555554
[36975.375044] Call Trace:
[36975.375046]  <TASK>
[36975.375049]  ? show_regs+0x6d/0x80
[36975.375056]  ? __warn+0x89/0x160
[36975.375060]  ? hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.375157]  ? report_bug+0x17e/0x1b0
[36975.375162]  ? handle_bug+0x46/0x90
[36975.375167]  ? exc_invalid_op+0x18/0x80
[36975.375169]  ? asm_exc_invalid_op+0x1b/0x20
[36975.375175]  ? hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.375267]  hsw_power_well_enable+0xaa/0x1e0 [i915]
[36975.375366]  intel_power_well_enable+0x5c/0x80 [i915]
[36975.375455]  intel_power_well_get+0x28/0x40 [i915]
[36975.375545]  __intel_display_power_get_domain.part.0+0x59/0x80 [i915]
[36975.375638]  intel_power_domains_disable+0x57/0xb0 [i915]
[36975.375729]  i915_driver_remove+0x3d/0x140 [i915]
[36975.375801]  i915_pci_remove+0x1e/0x40 [i915]
[36975.375873]  pci_device_remove+0x3e/0xb0
[36975.375878]  device_remove+0x40/0x80
[36975.375883]  device_release_driver_internal+0x20b/0x270
[36975.375886]  ? bus_find_device+0xb8/0xf0
[36975.375890]  device_driver_detach+0x14/0x20
[36975.375892]  unbind_store+0xac/0xc0
[36975.375895]  drv_attr_store+0x21/0x50
[36975.375898]  sysfs_kf_write+0x3b/0x60
[36975.375903]  kernfs_fop_write_iter+0x130/0x210
[36975.375907]  vfs_write+0x2a5/0x480
[36975.375912]  ksys_write+0x73/0x100
[36975.375915]  __x64_sys_write+0x19/0x30
[36975.375918]  x64_sys_call+0x23e1/0x24b0
[36975.375922]  do_syscall_64+0x81/0x170
[36975.375926]  ? enqueue_dl_entity+0x26f/0x8e0
[36975.375931]  ? sched_clock+0x10/0x30
[36975.375934]  ? timerqueue_del+0x31/0x50
[36975.375938]  ? timerqueue_add+0x69/0xd0
[36975.375940]  ? psi_group_change+0x1fb/0x460
[36975.375943]  ? sched_clock+0x10/0x30
[36975.375945]  ? psi_task_switch+0xd3/0x240
[36975.375949]  ? raw_spin_rq_unlock+0x10/0x40
[36975.375953]  ? finish_task_switch.isra.0+0x8c/0x310
[36975.375957]  ? __schedule+0x409/0x15e0
[36975.375960]  ? wake_up_process+0x15/0x30
[36975.375964]  ? __rseq_handle_notify_resume+0xa5/0x4d0
[36975.375969]  ? irqentry_exit_to_user_mode+0x7e/0x260
[36975.375973]  ? irqentry_exit+0x43/0x50
[36975.375976]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[36975.375979] RIP: 0033:0x7fb30f677240
[36975.376010] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[36975.376014] RSP: 002b:00007fff6e68dca8 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[36975.376017] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb30f677240
[36975.376019] RDX: 000000000000000d RSI: 0000608c3994ed80 RDI: 0000000000000001
[36975.376021] RBP: 0000608c3994ed80 R08: 0000000000000007 R09: 0000000000000073
[36975.376023] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[36975.376025] R13: 00007fb30f752760 R14: 000000000000000d R15: 00007fb30f74d9e0
[36975.376028]  </TASK>
[36975.376029] ---[ end trace 0000000000000000 ]---
[36975.381296] ------------[ cut here ]------------
[36975.381300] i915 0000:10:00.0: drm_WARN_ON(intel_de_wait_for_set(dev_priv, ((const i915_reg_t){ .reg = (0x42000) }), (1 << (27 - (pg))), 1))
[36975.381313] WARNING: CPU: 19 PID: 1967588 at drivers/gpu/drm/i915/display/intel_display_power_well.c:337 gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.381448] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36975.381508]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36975.381572] CPU: 19 PID: 1967588 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[36975.381576] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36975.381578] RIP: 0010:gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.381689] Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 e3 08 10 c4 48 c7 c1 70 13 c5 c1 48 89 da 48 c7 c7 40 d8 c7 c1 48 89 c6 e8 1a 0b 71 c3 <0f> 0b 48 8b 5d f8 c9 31 c0 31 d2 31 c9 31 f6 31 ff 45 31 c0 45 31
[36975.381693] RSP: 0018:ffffbf48909e7998 EFLAGS: 00010246
[36975.381696] RAX: 0000000000000000 RBX: ffff9f7142558a20 RCX: 0000000000000000
[36975.381699] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36975.381701] RBP: ffffbf48909e79a8 R08: 0000000000000000 R09: 0000000000000000
[36975.381703] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f7151df28a0
[36975.381705] R13: 0000000000000006 R14: ffff9f7157275cc8 R15: 0000000000045404
[36975.381707] FS:  00007fb30f57c740(0000) GS:ffff9f803eb80000(0000) knlGS:0000000000000000
[36975.381710] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36975.381712] CR2: 000071f396964170 CR3: 00000006540bc000 CR4: 0000000000f50ef0
[36975.381715] PKRU: 55555554
[36975.381716] Call Trace:
[36975.381718]  <TASK>
[36975.381720]  ? show_regs+0x6d/0x80
[36975.381724]  ? __warn+0x89/0x160
[36975.381727]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.381829]  ? report_bug+0x17e/0x1b0
[36975.381833]  ? handle_bug+0x46/0x90
[36975.381835]  ? exc_invalid_op+0x18/0x80
[36975.381837]  ? asm_exc_invalid_op+0x1b/0x20
[36975.381841]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.381940]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.382037]  hsw_power_well_enable+0x17a/0x1e0 [i915]
[36975.382133]  intel_power_well_enable+0x5c/0x80 [i915]
[36975.382228]  intel_power_well_get+0x28/0x40 [i915]
[36975.382322]  __intel_display_power_get_domain.part.0+0x59/0x80 [i915]
[36975.382427]  intel_power_domains_disable+0x57/0xb0 [i915]
[36975.382564]  i915_driver_remove+0x3d/0x140 [i915]
[36975.382729]  i915_pci_remove+0x1e/0x40 [i915]
[36975.382807]  pci_device_remove+0x3e/0xb0
[36975.382810]  device_remove+0x40/0x80
[36975.382813]  device_release_driver_internal+0x20b/0x270
[36975.382816]  ? bus_find_device+0xb8/0xf0
[36975.382819]  device_driver_detach+0x14/0x20
[36975.382822]  unbind_store+0xac/0xc0
[36975.382825]  drv_attr_store+0x21/0x50
[36975.382828]  sysfs_kf_write+0x3b/0x60
[36975.382831]  kernfs_fop_write_iter+0x130/0x210
[36975.382835]  vfs_write+0x2a5/0x480
[36975.382839]  ksys_write+0x73/0x100
[36975.382842]  __x64_sys_write+0x19/0x30
[36975.382845]  x64_sys_call+0x23e1/0x24b0
[36975.382848]  do_syscall_64+0x81/0x170
[36975.382851]  ? enqueue_dl_entity+0x26f/0x8e0
[36975.382855]  ? sched_clock+0x10/0x30
[36975.382858]  ? timerqueue_del+0x31/0x50
[36975.382860]  ? timerqueue_add+0x69/0xd0
[36975.382863]  ? psi_group_change+0x1fb/0x460
[36975.382865]  ? sched_clock+0x10/0x30
[36975.382868]  ? psi_task_switch+0xd3/0x240
[36975.382871]  ? raw_spin_rq_unlock+0x10/0x40
[36975.382874]  ? finish_task_switch.isra.0+0x8c/0x310
[36975.382877]  ? __schedule+0x409/0x15e0
[36975.382880]  ? wake_up_process+0x15/0x30
[36975.382884]  ? __rseq_handle_notify_resume+0xa5/0x4d0
[36975.382887]  ? irqentry_exit_to_user_mode+0x7e/0x260
[36975.382891]  ? irqentry_exit+0x43/0x50
[36975.382894]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[36975.382898] RIP: 0033:0x7fb30f677240
[36975.382907] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[36975.382911] RSP: 002b:00007fff6e68dca8 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[36975.382915] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb30f677240
[36975.382917] RDX: 000000000000000d RSI: 0000608c3994ed80 RDI: 0000000000000001
[36975.382919] RBP: 0000608c3994ed80 R08: 0000000000000007 R09: 0000000000000073
[36975.382921] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[36975.382923] R13: 00007fb30f752760 R14: 000000000000000d R15: 00007fb30f74d9e0
[36975.382926]  </TASK>
[36975.382928] ---[ end trace 0000000000000000 ]---
[36975.388966] ------------[ cut here ]------------
[36975.388968] i915 0000:10:00.0: drm_WARN_ON(!timeout_expected)
[36975.388974] WARNING: CPU: 19 PID: 1967588 at drivers/gpu/drm/i915/display/intel_display_power_well.c:283 hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.389040] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36975.389062]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36975.389085] CPU: 19 PID: 1967588 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[36975.389087] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36975.389089] RIP: 0010:hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.389149] Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 a1 05 10 c4 48 c7 c1 88 14 c5 c1 48 89 da 48 c7 c7 40 d8 c7 c1 48 89 c6 e8 d8 07 71 c3 <0f> 0b e9 74 ff ff ff 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90
[36975.389151] RSP: 0018:ffffbf48909e7980 EFLAGS: 00010246
[36975.389153] RAX: 0000000000000000 RBX: ffff9f7142558a20 RCX: 0000000000000000
[36975.389154] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36975.389155] RBP: ffffbf48909e79a8 R08: 0000000000000000 R09: 0000000000000000
[36975.389156] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f7157274000
[36975.389157] R13: ffff9f7151df28c0 R14: ffffffffc1bec850 R15: 0000000000045404
[36975.389159] FS:  00007fb30f57c740(0000) GS:ffff9f803eb80000(0000) knlGS:0000000000000000
[36975.389160] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36975.389161] CR2: 000071f396964170 CR3: 00000006540bc000 CR4: 0000000000f50ef0
[36975.389163] PKRU: 55555554
[36975.389164] Call Trace:
[36975.389164]  <TASK>
[36975.389165]  ? show_regs+0x6d/0x80
[36975.389168]  ? __warn+0x89/0x160
[36975.389169]  ? hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.389225]  ? report_bug+0x17e/0x1b0
[36975.389227]  ? handle_bug+0x46/0x90
[36975.389229]  ? exc_invalid_op+0x18/0x80
[36975.389230]  ? asm_exc_invalid_op+0x1b/0x20
[36975.389232]  ? hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.389288]  hsw_power_well_enable+0xaa/0x1e0 [i915]
[36975.389345]  intel_power_well_enable+0x5c/0x80 [i915]
[36975.389410]  intel_power_well_get+0x28/0x40 [i915]
[36975.389498]  __intel_display_power_get_domain.part.0+0x59/0x80 [i915]
[36975.389592]  intel_power_domains_disable+0x57/0xb0 [i915]
[36975.389693]  i915_driver_remove+0x3d/0x140 [i915]
[36975.389789]  i915_pci_remove+0x1e/0x40 [i915]
[36975.389841]  pci_device_remove+0x3e/0xb0
[36975.389843]  device_remove+0x40/0x80
[36975.389845]  device_release_driver_internal+0x20b/0x270
[36975.389846]  ? bus_find_device+0xb8/0xf0
[36975.389848]  device_driver_detach+0x14/0x20
[36975.389850]  unbind_store+0xac/0xc0
[36975.389852]  drv_attr_store+0x21/0x50
[36975.389853]  sysfs_kf_write+0x3b/0x60
[36975.389855]  kernfs_fop_write_iter+0x130/0x210
[36975.389858]  vfs_write+0x2a5/0x480
[36975.389860]  ksys_write+0x73/0x100
[36975.389862]  __x64_sys_write+0x19/0x30
[36975.389863]  x64_sys_call+0x23e1/0x24b0
[36975.389865]  do_syscall_64+0x81/0x170
[36975.389867]  ? enqueue_dl_entity+0x26f/0x8e0
[36975.389869]  ? sched_clock+0x10/0x30
[36975.389871]  ? timerqueue_del+0x31/0x50
[36975.389872]  ? timerqueue_add+0x69/0xd0
[36975.389873]  ? psi_group_change+0x1fb/0x460
[36975.389875]  ? sched_clock+0x10/0x30
[36975.389877]  ? psi_task_switch+0xd3/0x240
[36975.389878]  ? raw_spin_rq_unlock+0x10/0x40
[36975.389880]  ? finish_task_switch.isra.0+0x8c/0x310
[36975.389882]  ? __schedule+0x409/0x15e0
[36975.389883]  ? wake_up_process+0x15/0x30
[36975.389885]  ? __rseq_handle_notify_resume+0xa5/0x4d0
[36975.389887]  ? irqentry_exit_to_user_mode+0x7e/0x260
[36975.389890]  ? irqentry_exit+0x43/0x50
[36975.389891]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[36975.389894] RIP: 0033:0x7fb30f677240
[36975.389898] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[36975.389900] RSP: 002b:00007fff6e68dca8 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[36975.389902] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb30f677240
[36975.389904] RDX: 000000000000000d RSI: 0000608c3994ed80 RDI: 0000000000000001
[36975.389905] RBP: 0000608c3994ed80 R08: 0000000000000007 R09: 0000000000000073
[36975.389906] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[36975.389907] R13: 00007fb30f752760 R14: 000000000000000d R15: 00007fb30f74d9e0
[36975.389909]  </TASK>
[36975.389910] ---[ end trace 0000000000000000 ]---
[36975.395120] ------------[ cut here ]------------
[36975.395123] i915 0000:10:00.0: drm_WARN_ON(intel_de_wait_for_set(dev_priv, ((const i915_reg_t){ .reg = (0x42000) }), (1 << (27 - (pg))), 1))
[36975.395130] WARNING: CPU: 19 PID: 1967588 at drivers/gpu/drm/i915/display/intel_display_power_well.c:337 gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.395197] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36975.395218]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36975.395243] CPU: 19 PID: 1967588 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[36975.395245] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36975.395246] RIP: 0010:gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.395309] Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 e3 08 10 c4 48 c7 c1 70 13 c5 c1 48 89 da 48 c7 c7 40 d8 c7 c1 48 89 c6 e8 1a 0b 71 c3 <0f> 0b 48 8b 5d f8 c9 31 c0 31 d2 31 c9 31 f6 31 ff 45 31 c0 45 31
[36975.395312] RSP: 0018:ffffbf48909e7998 EFLAGS: 00010246
[36975.395313] RAX: 0000000000000000 RBX: ffff9f7142558a20 RCX: 0000000000000000
[36975.395314] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36975.395315] RBP: ffffbf48909e79a8 R08: 0000000000000000 R09: 0000000000000000
[36975.395317] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f7151df28c0
[36975.395318] R13: 0000000000000007 R14: ffff9f7157275cc8 R15: 0000000000045404
[36975.395319] FS:  00007fb30f57c740(0000) GS:ffff9f803eb80000(0000) knlGS:0000000000000000
[36975.395321] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36975.395322] CR2: 000071f396964170 CR3: 00000006540bc000 CR4: 0000000000f50ef0
[36975.395323] PKRU: 55555554
[36975.395324] Call Trace:
[36975.395325]  <TASK>
[36975.395326]  ? show_regs+0x6d/0x80
[36975.395329]  ? __warn+0x89/0x160
[36975.395334]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.395415]  ? report_bug+0x17e/0x1b0
[36975.395418]  ? handle_bug+0x46/0x90
[36975.395420]  ? exc_invalid_op+0x18/0x80
[36975.395423]  ? asm_exc_invalid_op+0x1b/0x20
[36975.395427]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.395509]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.395592]  hsw_power_well_enable+0x17a/0x1e0 [i915]
[36975.395694]  intel_power_well_enable+0x5c/0x80 [i915]
[36975.395800]  intel_power_well_get+0x28/0x40 [i915]
[36975.395878]  __intel_display_power_get_domain.part.0+0x59/0x80 [i915]
[36975.395946]  intel_power_domains_disable+0x57/0xb0 [i915]
[36975.396003]  i915_driver_remove+0x3d/0x140 [i915]
[36975.396049]  i915_pci_remove+0x1e/0x40 [i915]
[36975.396094]  pci_device_remove+0x3e/0xb0
[36975.396096]  device_remove+0x40/0x80
[36975.396097]  device_release_driver_internal+0x20b/0x270
[36975.396099]  ? bus_find_device+0xb8/0xf0
[36975.396101]  device_driver_detach+0x14/0x20
[36975.396103]  unbind_store+0xac/0xc0
[36975.396105]  drv_attr_store+0x21/0x50
[36975.396106]  sysfs_kf_write+0x3b/0x60
[36975.396109]  kernfs_fop_write_iter+0x130/0x210
[36975.396111]  vfs_write+0x2a5/0x480
[36975.396113]  ksys_write+0x73/0x100
[36975.396115]  __x64_sys_write+0x19/0x30
[36975.396117]  x64_sys_call+0x23e1/0x24b0
[36975.396118]  do_syscall_64+0x81/0x170
[36975.396120]  ? enqueue_dl_entity+0x26f/0x8e0
[36975.396122]  ? sched_clock+0x10/0x30
[36975.396124]  ? timerqueue_del+0x31/0x50
[36975.396125]  ? timerqueue_add+0x69/0xd0
[36975.396127]  ? psi_group_change+0x1fb/0x460
[36975.396128]  ? sched_clock+0x10/0x30
[36975.396130]  ? psi_task_switch+0xd3/0x240
[36975.396131]  ? raw_spin_rq_unlock+0x10/0x40
[36975.396133]  ? finish_task_switch.isra.0+0x8c/0x310
[36975.396135]  ? __schedule+0x409/0x15e0
[36975.396137]  ? wake_up_process+0x15/0x30
[36975.396139]  ? __rseq_handle_notify_resume+0xa5/0x4d0
[36975.396141]  ? irqentry_exit_to_user_mode+0x7e/0x260
[36975.396143]  ? irqentry_exit+0x43/0x50
[36975.396145]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[36975.396147] RIP: 0033:0x7fb30f677240
[36975.396152] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[36975.396154] RSP: 002b:00007fff6e68dca8 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[36975.396156] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb30f677240
[36975.396158] RDX: 000000000000000d RSI: 0000608c3994ed80 RDI: 0000000000000001
[36975.396159] RBP: 0000608c3994ed80 R08: 0000000000000007 R09: 0000000000000073
[36975.396160] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[36975.396161] R13: 00007fb30f752760 R14: 000000000000000d R15: 00007fb30f74d9e0
[36975.396163]  </TASK>
[36975.396164] ---[ end trace 0000000000000000 ]---
[36975.402047] ------------[ cut here ]------------
[36975.402049] i915 0000:10:00.0: drm_WARN_ON(!timeout_expected)
[36975.402055] WARNING: CPU: 19 PID: 1967588 at drivers/gpu/drm/i915/display/intel_display_power_well.c:283 hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.402121] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36975.402143]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36975.402166] CPU: 19 PID: 1967588 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[36975.402168] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36975.402169] RIP: 0010:hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.402230] Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 a1 05 10 c4 48 c7 c1 88 14 c5 c1 48 89 da 48 c7 c7 40 d8 c7 c1 48 89 c6 e8 d8 07 71 c3 <0f> 0b e9 74 ff ff ff 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90
[36975.402233] RSP: 0018:ffffbf48909e7980 EFLAGS: 00010246
[36975.402235] RAX: 0000000000000000 RBX: ffff9f7142558a20 RCX: 0000000000000000
[36975.402236] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36975.402238] RBP: ffffbf48909e79a8 R08: 0000000000000000 R09: 0000000000000000
[36975.402239] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f7157274000
[36975.402240] R13: ffff9f7151df28e0 R14: ffffffffc1bec850 R15: 0000000000045404
[36975.402241] FS:  00007fb30f57c740(0000) GS:ffff9f803eb80000(0000) knlGS:0000000000000000
[36975.402243] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36975.402244] CR2: 000071f396964170 CR3: 00000006540bc000 CR4: 0000000000f50ef0
[36975.402246] PKRU: 55555554
[36975.402247] Call Trace:
[36975.402248]  <TASK>
[36975.402250]  ? show_regs+0x6d/0x80
[36975.402253]  ? __warn+0x89/0x160
[36975.402255]  ? hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.402365]  ? report_bug+0x17e/0x1b0
[36975.402368]  ? handle_bug+0x46/0x90
[36975.402370]  ? exc_invalid_op+0x18/0x80
[36975.402373]  ? asm_exc_invalid_op+0x1b/0x20
[36975.402377]  ? hsw_wait_for_power_well_enable+0x158/0x160 [i915]
[36975.402478]  hsw_power_well_enable+0xaa/0x1e0 [i915]
[36975.402533]  intel_power_well_enable+0x5c/0x80 [i915]
[36975.402588]  intel_power_well_get+0x28/0x40 [i915]
[36975.402643]  __intel_display_power_get_domain.part.0+0x59/0x80 [i915]
[36975.402700]  intel_power_domains_disable+0x57/0xb0 [i915]
[36975.402755]  i915_driver_remove+0x3d/0x140 [i915]
[36975.402800]  i915_pci_remove+0x1e/0x40 [i915]
[36975.402845]  pci_device_remove+0x3e/0xb0
[36975.402847]  device_remove+0x40/0x80
[36975.402849]  device_release_driver_internal+0x20b/0x270
[36975.402850]  ? bus_find_device+0xb8/0xf0
[36975.402852]  device_driver_detach+0x14/0x20
[36975.402855]  unbind_store+0xac/0xc0
[36975.402857]  drv_attr_store+0x21/0x50
[36975.402858]  sysfs_kf_write+0x3b/0x60
[36975.402860]  kernfs_fop_write_iter+0x130/0x210
[36975.402863]  vfs_write+0x2a5/0x480
[36975.402865]  ksys_write+0x73/0x100
[36975.402867]  __x64_sys_write+0x19/0x30
[36975.402868]  x64_sys_call+0x23e1/0x24b0
[36975.402870]  do_syscall_64+0x81/0x170
[36975.402872]  ? enqueue_dl_entity+0x26f/0x8e0
[36975.402874]  ? sched_clock+0x10/0x30
[36975.402876]  ? timerqueue_del+0x31/0x50
[36975.402877]  ? timerqueue_add+0x69/0xd0
[36975.402878]  ? psi_group_change+0x1fb/0x460
[36975.402880]  ? sched_clock+0x10/0x30
[36975.402882]  ? psi_task_switch+0xd3/0x240
[36975.402883]  ? raw_spin_rq_unlock+0x10/0x40
[36975.402885]  ? finish_task_switch.isra.0+0x8c/0x310
[36975.402887]  ? __schedule+0x409/0x15e0
[36975.402889]  ? wake_up_process+0x15/0x30
[36975.402891]  ? __rseq_handle_notify_resume+0xa5/0x4d0
[36975.402893]  ? irqentry_exit_to_user_mode+0x7e/0x260
[36975.402895]  ? irqentry_exit+0x43/0x50
[36975.402897]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[36975.402899] RIP: 0033:0x7fb30f677240
[36975.402903] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[36975.402905] RSP: 002b:00007fff6e68dca8 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[36975.402907] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb30f677240
[36975.402909] RDX: 000000000000000d RSI: 0000608c3994ed80 RDI: 0000000000000001
[36975.402910] RBP: 0000608c3994ed80 R08: 0000000000000007 R09: 0000000000000073
[36975.402911] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[36975.402912] R13: 00007fb30f752760 R14: 000000000000000d R15: 00007fb30f74d9e0
[36975.402914]  </TASK>
[36975.402915] ---[ end trace 0000000000000000 ]---
[36975.408143] ------------[ cut here ]------------
[36975.408146] i915 0000:10:00.0: drm_WARN_ON(intel_de_wait_for_set(dev_priv, ((const i915_reg_t){ .reg = (0x42000) }), (1 << (27 - (pg))), 1))
[36975.408154] WARNING: CPU: 19 PID: 1967588 at drivers/gpu/drm/i915/display/intel_display_power_well.c:337 gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.408219] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36975.408240]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36975.408263] CPU: 19 PID: 1967588 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[36975.408265] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36975.408267] RIP: 0010:gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.408326] Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 e3 08 10 c4 48 c7 c1 70 13 c5 c1 48 89 da 48 c7 c7 40 d8 c7 c1 48 89 c6 e8 1a 0b 71 c3 <0f> 0b 48 8b 5d f8 c9 31 c0 31 d2 31 c9 31 f6 31 ff 45 31 c0 45 31
[36975.408329] RSP: 0018:ffffbf48909e7998 EFLAGS: 00010246
[36975.408330] RAX: 0000000000000000 RBX: ffff9f7142558a20 RCX: 0000000000000000
[36975.408335] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36975.408337] RBP: ffffbf48909e79a8 R08: 0000000000000000 R09: 0000000000000000
[36975.408338] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f7151df28e0
[36975.408339] R13: 0000000000000008 R14: ffff9f7157275cc8 R15: 0000000000045404
[36975.408340] FS:  00007fb30f57c740(0000) GS:ffff9f803eb80000(0000) knlGS:0000000000000000
[36975.408342] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36975.408343] CR2: 000071f396964170 CR3: 00000006540bc000 CR4: 0000000000f50ef0
[36975.408345] PKRU: 55555554
[36975.408346] Call Trace:
[36975.408347]  <TASK>
[36975.408348]  ? show_regs+0x6d/0x80
[36975.408350]  ? __warn+0x89/0x160
[36975.408352]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.408457]  ? report_bug+0x17e/0x1b0
[36975.408461]  ? handle_bug+0x46/0x90
[36975.408463]  ? exc_invalid_op+0x18/0x80
[36975.408466]  ? asm_exc_invalid_op+0x1b/0x20
[36975.408469]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.408547]  ? gen9_wait_for_power_well_fuses+0x96/0xc0 [i915]
[36975.408601]  hsw_power_well_enable+0x17a/0x1e0 [i915]
[36975.408656]  intel_power_well_enable+0x5c/0x80 [i915]
[36975.408710]  intel_power_well_get+0x28/0x40 [i915]
[36975.408764]  __intel_display_power_get_domain.part.0+0x59/0x80 [i915]
[36975.408821]  intel_power_domains_disable+0x57/0xb0 [i915]
[36975.408876]  i915_driver_remove+0x3d/0x140 [i915]
[36975.408920]  i915_pci_remove+0x1e/0x40 [i915]
[36975.408965]  pci_device_remove+0x3e/0xb0
[36975.408967]  device_remove+0x40/0x80
[36975.408969]  device_release_driver_internal+0x20b/0x270
[36975.408970]  ? bus_find_device+0xb8/0xf0
[36975.408972]  device_driver_detach+0x14/0x20
[36975.408974]  unbind_store+0xac/0xc0
[36975.408976]  drv_attr_store+0x21/0x50
[36975.408977]  sysfs_kf_write+0x3b/0x60
[36975.408979]  kernfs_fop_write_iter+0x130/0x210
[36975.408982]  vfs_write+0x2a5/0x480
[36975.408984]  ksys_write+0x73/0x100
[36975.408986]  __x64_sys_write+0x19/0x30
[36975.408988]  x64_sys_call+0x23e1/0x24b0
[36975.408989]  do_syscall_64+0x81/0x170
[36975.408991]  ? enqueue_dl_entity+0x26f/0x8e0
[36975.408993]  ? sched_clock+0x10/0x30
[36975.408995]  ? timerqueue_del+0x31/0x50
[36975.408996]  ? timerqueue_add+0x69/0xd0
[36975.408997]  ? psi_group_change+0x1fb/0x460
[36975.408999]  ? sched_clock+0x10/0x30
[36975.409001]  ? psi_task_switch+0xd3/0x240
[36975.409002]  ? raw_spin_rq_unlock+0x10/0x40
[36975.409004]  ? finish_task_switch.isra.0+0x8c/0x310
[36975.409006]  ? __schedule+0x409/0x15e0
[36975.409008]  ? wake_up_process+0x15/0x30
[36975.409010]  ? __rseq_handle_notify_resume+0xa5/0x4d0
[36975.409012]  ? irqentry_exit_to_user_mode+0x7e/0x260
[36975.409014]  ? irqentry_exit+0x43/0x50
[36975.409016]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[36975.409018] RIP: 0033:0x7fb30f677240
[36975.409022] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[36975.409024] RSP: 002b:00007fff6e68dca8 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[36975.409026] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb30f677240
[36975.409027] RDX: 000000000000000d RSI: 0000608c3994ed80 RDI: 0000000000000001
[36975.409028] RBP: 0000608c3994ed80 R08: 0000000000000007 R09: 0000000000000073
[36975.409029] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[36975.409031] R13: 00007fb30f752760 R14: 000000000000000d R15: 00007fb30f74d9e0
[36975.409032]  </TASK>
[36975.409033] ---[ end trace 0000000000000000 ]---
[36975.410528] i915 0000:10:00.0: [drm] *ERROR* audio power refcount -1 after unbind
[36975.499355] ------------[ cut here ]------------
[36975.499358] i915 0000:10:00.0: i915 raw-wakerefs=65535 wakelocks=-2 on cleanup
[36975.499370] WARNING: CPU: 9 PID: 1967588 at drivers/gpu/drm/i915/intel_runtime_pm.c:444 intel_runtime_pm_driver_release+0x75/0x90 [i915]
[36975.499434] Modules linked in: nf_conntrack_netlink xt_tcpudp xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 mei_hdcp mei_pxp bonding tls softdog sunrpc nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei intel_rapl_msr intel_rapl_common xe snd_hda_codec_hdmi drm_gpuvm drm_exec gpu_sched drm_suballoc_helper drm_ttm_helper edac_mce_amd iwlmvm kvm_amd mac80211 i915 kvm libarc4 snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crct10dif_pclmul snd_hda_codec polyval_clmulni polyval_generic btusb ghash_clmulni_intel snd_hda_core btrtl sha256_ssse3 drm_buddy ttm sha1_ssse3 btintel snd_hwdep iwlwifi aesni_intel btbcm crypto_simd drm_display_helper snd_pcm btmtk cryptd snd_timer cec bluetooth snd rc_core rapl cfg80211 video mxm_wmi wmi_bmof soundcore
[36975.499463]  pcspkr ecdh_generic ccp k10temp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci igb nvme xhci_pci_renesas crc32_pclmul ahci i2c_piix4 i2c_algo_bit nvme_core libahci dca xhci_hcd nvme_auth wmi
[36975.499495] CPU: 9 PID: 1967588 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[36975.499498] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[36975.499500] RIP: 0010:intel_runtime_pm_driver_release+0x75/0x90 [i915]
[36975.499560] Code: 10 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 73 0d 20 c4 45 89 e8 44 89 e1 48 89 da 48 89 c6 48 c7 c7 c8 97 c3 c1 e8 ab 0f 81 c3 <0f> 0b 5b 41 5c 41 5d 5d 31 c0 31 d2 31 c9 31 f6 31 ff 45 31 c0 c3
[36975.499563] RSP: 0018:ffffbf48909e79e8 EFLAGS: 00010246
[36975.499565] RAX: 0000000000000000 RBX: ffff9f7142558a20 RCX: 0000000000000000
[36975.499567] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[36975.499569] RBP: ffffbf48909e7a00 R08: 0000000000000000 R09: 0000000000000000
[36975.499570] R10: 0000000000000000 R11: 0000000000000000 R12: 000000000000ffff
[36975.499572] R13: 00000000fffffffe R14: ffff9f71425fc0c8 R15: ffff9f71425fc380
[36975.499573] FS:  00007fb30f57c740(0000) GS:ffff9f803e680000(0000) knlGS:0000000000000000
[36975.499576] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36975.499577] CR2: 00005daedaa97100 CR3: 00000006540bc000 CR4: 0000000000f50ef0
[36975.499579] PKRU: 55555554
[36975.499580] Call Trace:
[36975.499581]  <TASK>
[36975.499583]  ? show_regs+0x6d/0x80
[36975.499586]  ? __warn+0x89/0x160
[36975.499588]  ? intel_runtime_pm_driver_release+0x75/0x90 [i915]
[36975.499647]  ? report_bug+0x17e/0x1b0
[36975.499650]  ? handle_bug+0x46/0x90
[36975.499652]  ? exc_invalid_op+0x18/0x80
[36975.499653]  ? asm_exc_invalid_op+0x1b/0x20
[36975.499656]  ? intel_runtime_pm_driver_release+0x75/0x90 [i915]
[36975.499715]  ? intel_runtime_pm_driver_release+0x75/0x90 [i915]
[36975.499774]  i915_driver_release+0x76/0xa0 [i915]
[36975.499831]  devm_drm_dev_init_release+0x5e/0x90
[36975.499835]  devm_action_release+0x12/0x30
[36975.499837]  release_nodes+0x42/0xd0
[36975.499839]  devres_release_all+0x97/0xe0
[36975.499842]  device_unbind_cleanup+0x12/0x80
[36975.499845]  device_release_driver_internal+0x230/0x270
[36975.499847]  ? bus_find_device+0xb8/0xf0
[36975.499849]  device_driver_detach+0x14/0x20
[36975.499851]  unbind_store+0xac/0xc0
[36975.499854]  drv_attr_store+0x21/0x50
[36975.499856]  sysfs_kf_write+0x3b/0x60
[36975.499858]  kernfs_fop_write_iter+0x130/0x210
[36975.499861]  vfs_write+0x2a5/0x480
[36975.499864]  ksys_write+0x73/0x100
[36975.499866]  __x64_sys_write+0x19/0x30
[36975.499869]  x64_sys_call+0x23e1/0x24b0
[36975.499871]  do_syscall_64+0x81/0x170
[36975.499873]  ? enqueue_dl_entity+0x26f/0x8e0
[36975.499876]  ? sched_clock+0x10/0x30
[36975.499878]  ? timerqueue_del+0x31/0x50
[36975.499880]  ? timerqueue_add+0x69/0xd0
[36975.499882]  ? psi_group_change+0x1fb/0x460
[36975.499883]  ? sched_clock+0x10/0x30
[36975.499886]  ? psi_task_switch+0xd3/0x240
[36975.499887]  ? raw_spin_rq_unlock+0x10/0x40
[36975.499890]  ? finish_task_switch.isra.0+0x8c/0x310
[36975.499892]  ? __schedule+0x409/0x15e0
[36975.499894]  ? wake_up_process+0x15/0x30
[36975.499897]  ? __rseq_handle_notify_resume+0xa5/0x4d0
[36975.499900]  ? irqentry_exit_to_user_mode+0x7e/0x260
[36975.499902]  ? irqentry_exit+0x43/0x50
[36975.499905]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[36975.499908] RIP: 0033:0x7fb30f677240
[36975.499913] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[36975.499917] RSP: 002b:00007fff6e68dca8 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[36975.499919] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb30f677240
[36975.499921] RDX: 000000000000000d RSI: 0000608c3994ed80 RDI: 0000000000000001
[36975.499922] RBP: 0000608c3994ed80 R08: 0000000000000007 R09: 0000000000000073
[36975.499924] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[36975.499925] R13: 00007fb30f752760 R14: 000000000000000d R15: 00007fb30f74d9e0
[36975.499927]  </TASK>
[36975.499928] ---[ end trace 0000000000000000 ]---
[36975.506812] vfio-pci 0000:10:00.0: vgaarb: deactivate vga console
[36975.506815] vfio-pci 0000:10:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io
[36981.964593] tap101i0: entered promiscuous mode
[  145.861628] i915 0000:10:00.0: All device reset methods disabled by user
[  145.862522] Console: switching to colour dummy device 80x25
[  147.002511] vfio-pci 0000:10:00.0: vgaarb: deactivate vga console
[  147.002518] vfio-pci 0000:10:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io
[  149.059792] ------------[ cut here ]------------
[  149.059809] WARNING: CPU: 17 PID: 4816 at sound/hda/hdac_component.c:341 snd_hdac_acomp_exit+0x8f/0xb0 [snd_hda_core]
[  149.059854] Modules linked in: xt_tcpudp nf_conntrack_netlink xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 softdog sunrpc mei_hdcp mei_pxp bonding tls nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei xe drm_gpuvm iwlmvm drm_exec gpu_sched drm_suballoc_helper intel_rapl_msr drm_ttm_helper intel_rapl_common snd_hda_codec_hdmi mac80211 edac_mce_amd kvm_amd libarc4 i915 kvm snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec crct10dif_pclmul polyval_clmulni polyval_generic ghash_clmulni_intel snd_hda_core drm_buddy sha256_ssse3 ttm sha1_ssse3 btusb snd_hwdep iwlwifi btrtl aesni_intel drm_display_helper snd_pcm btintel btbcm crypto_simd cec snd_timer btmtk cryptd rc_core bluetooth snd wmi_bmof rapl video cfg80211 mxm_wmi soundcore
[  149.059985]  pcspkr ecdh_generic k10temp ccp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci nvme xhci_pci_renesas crc32_pclmul igb i2c_piix4 nvme_core ahci i2c_algo_bit xhci_hcd libahci dca nvme_auth wmi
[  149.060118] CPU: 17 PID: 4816 Comm: driverctl Tainted: P        W  O       6.8.12-2-pve #1
[  149.060128] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[  149.060137] RIP: 0010:snd_hdac_acomp_exit+0x8f/0xb0 [snd_hda_core]
[  149.060163] Code: c7 75 c1 e8 b3 d7 d8 d1 31 c0 5b 41 5c 5d 31 d2 31 c9 31 f6 31 ff c3 cc cc cc cc 31 c0 31 d2 31 c9 31 f6 31 ff c3 cc cc cc cc <0f> 0b 48 8b 50 08 48 85 d2 74 90 48 8b 38 48 8b 42 10 ff d0 0f 1f
[  149.060170] RSP: 0018:ffffb1720116f928 EFLAGS: 00010286
[  149.060174] RAX: ffff934845c34928 RBX: ffff934854002028 RCX: 0000000000000000
[  149.060179] RDX: 0000000000000000 RSI: ffffffffffffffff RDI: ffff934854002028
[  149.060182] RBP: ffffb1720116f938 R08: 0000000000000000 R09: 0000000000000000
[  149.060185] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9348425ca0c8
[  149.060188] R13: ffff93484420b000 R14: 0000000000000000 R15: ffff9348425b8148
[  149.060192] FS:  00007f7d094ea740(0000) GS:ffff93573ea80000(0000) knlGS:0000000000000000
[  149.060196] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  149.060199] CR2: 000000c0004c0000 CR3: 0000000133946000 CR4: 0000000000f50ef0
[  149.060203] PKRU: 55555554
[  149.060205] Call Trace:
[  149.060208]  <TASK>
[  149.060212]  ? show_regs+0x6d/0x80
[  149.060221]  ? __warn+0x89/0x160
[  149.060226]  ? snd_hdac_acomp_exit+0x8f/0xb0 [snd_hda_core]
[  149.060242]  ? report_bug+0x17e/0x1b0
[  149.060249]  ? handle_bug+0x46/0x90
[  149.060254]  ? exc_invalid_op+0x18/0x80
[  149.060258]  ? asm_exc_invalid_op+0x1b/0x20
[  149.060265]  ? snd_hdac_acomp_exit+0x8f/0xb0 [snd_hda_core]
[  149.060281]  azx_free+0x1a1/0x220 [snd_hda_intel]
[  149.060290]  azx_dev_free+0x12/0x20 [snd_hda_intel]
[  149.060300]  __snd_device_free+0x47/0xe0 [snd]
[  149.060316]  snd_device_free_all+0x64/0x90 [snd]
[  149.060329]  release_card_device+0x3e/0xc0 [snd]
[  149.060342]  device_release+0x35/0xa0
[  149.060349]  kobject_put+0xb8/0x200
[  149.060354]  put_device+0x13/0x30
[  149.060358]  snd_card_free+0x7a/0xb0 [snd]
[  149.060371]  azx_remove+0x6d/0x80 [snd_hda_intel]
[  149.060380]  pci_device_remove+0x3e/0xb0
[  149.060386]  device_remove+0x40/0x80
[  149.060390]  device_release_driver_internal+0x20b/0x270
[  149.060395]  ? bus_find_device+0xb8/0xf0
[  149.060400]  device_driver_detach+0x14/0x20
[  149.060404]  unbind_store+0xac/0xc0
[  149.060409]  drv_attr_store+0x21/0x50
[  149.060413]  sysfs_kf_write+0x3b/0x60
[  149.060420]  kernfs_fop_write_iter+0x130/0x210
[  149.060427]  vfs_write+0x2a5/0x480
[  149.060435]  ksys_write+0x73/0x100
[  149.060440]  __x64_sys_write+0x19/0x30
[  149.060444]  x64_sys_call+0x23e1/0x24b0
[  149.060449]  do_syscall_64+0x81/0x170
[  149.060456]  ? filp_flush+0x57/0x90
[  149.060462]  ? syscall_exit_to_user_mode+0x89/0x260
[  149.060468]  ? do_syscall_64+0x8d/0x170
[  149.060472]  ? syscall_exit_to_user_mode+0x89/0x260
[  149.060477]  ? do_syscall_64+0x8d/0x170
[  149.060482]  ? __count_memcg_events+0x6f/0xe0
[  149.060489]  ? count_memcg_events.constprop.0+0x2a/0x50
[  149.060496]  ? handle_mm_fault+0xad/0x380
[  149.060501]  ? do_user_addr_fault+0x337/0x660
[  149.060507]  ? irqentry_exit_to_user_mode+0x7e/0x260
[  149.060512]  ? irqentry_exit+0x43/0x50
[  149.060517]  ? exc_page_fault+0x94/0x1b0
[  149.060522]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[  149.060527] RIP: 0033:0x7f7d095e5240
[  149.060561] Code: 40 00 48 8b 15 c1 9b 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 80 3d a1 23 0e 00 00 74 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 48 83 ec 28 48 89
[  149.060567] RSP: 002b:00007fff71cbe818 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[  149.060572] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007f7d095e5240
[  149.060575] RDX: 000000000000000d RSI: 00005c89a4538d80 RDI: 0000000000000001
[  149.060579] RBP: 00005c89a4538d80 R08: 0000000000000007 R09: 0000000000000073
[  149.060583] R10: 0000000000000000 R11: 0000000000000202 R12: 000000000000000d
[  149.060586] R13: 00007f7d096c0760 R14: 000000000000000d R15: 00007f7d096bb9e0
[  149.060590]  </TASK>
[  149.060592] ---[ end trace 0000000000000000 ]---
[  153.310890] tap101i0: entered promiscuous mode
when rebind to host with reset method
[  985.416494] vfio-pci 0000:10:00.0: not ready 1023ms after bus reset; giving up
[  987.424628] Bluetooth: hci0: Opcode 0x2003 failed: -110
[  988.415123] Bluetooth: hci0: MSFT supported features length mismatch
[  991.456557] Bluetooth: hci0: command tx timeout
[ 1009.405453] watchdog: BUG: soft lockup - CPU#20 stuck for 27s! [CPU 2/KVM:4959]
[ 1009.405463] Modules linked in: xt_tcpudp nf_conntrack_netlink xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 softdog sunrpc mei_hdcp mei_pxp bonding tls nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei xe drm_gpuvm iwlmvm drm_exec gpu_sched drm_suballoc_helper intel_rapl_msr drm_ttm_helper intel_rapl_common snd_hda_codec_hdmi mac80211 edac_mce_amd kvm_amd libarc4 i915 kvm snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec crct10dif_pclmul polyval_clmulni polyval_generic ghash_clmulni_intel snd_hda_core drm_buddy sha256_ssse3 ttm sha1_ssse3 btusb snd_hwdep iwlwifi btrtl aesni_intel drm_display_helper snd_pcm btintel btbcm crypto_simd cec snd_timer btmtk cryptd rc_core bluetooth snd wmi_bmof rapl video cfg80211 mxm_wmi soundcore
[ 1009.405519]  pcspkr ecdh_generic k10temp ccp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci nvme xhci_pci_renesas crc32_pclmul igb i2c_piix4 nvme_core ahci i2c_algo_bit xhci_hcd libahci dca nvme_auth wmi
[ 1009.405561] CPU: 20 PID: 4959 Comm: CPU 2/KVM Tainted: P        W  O       6.8.12-2-pve #1
[ 1009.405564] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[ 1009.405566] RIP: 0010:pci_mmcfg_read+0xcb/0x110
[ 1009.405573] Code: 45 31 c9 c3 cc cc cc cc 4c 01 e8 66 8b 00 0f b7 c0 41 89 04 24 eb c9 4c 01 e8 8a 00 0f b6 c0 41 89 04 24 eb bb 4c 01 e8 8b 00 <41> 89 04 24 eb b0 e8 8a 5b 12 ff 41 c7 04 24 ff ff ff ff 48 83 c4
[ 1009.405576] RSP: 0018:ffffb17206b5f6b8 EFLAGS: 00000286
[ 1009.405578] RAX: 00000000ffffffff RBX: 0000000001000000 RCX: 0000000000000ffc
[ 1009.405580] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[ 1009.405581] RBP: ffffb17206b5f6e8 R08: 0000000000000004 R09: ffffb17206b5f70c
[ 1009.405583] R10: 0000000000000010 R11: ffffffff93a8d8c0 R12: ffffb17206b5f70c
[ 1009.405584] R13: 0000000000000ffc R14: 0000000000000000 R15: 0000000000000004
[ 1009.405586] FS:  0000000000000000(0000) GS:ffff93573ec00000(0000) knlGS:0000000000000000
[ 1009.405587] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1009.405588] CR2: 000072b2afa61a1c CR3: 0000000108552000 CR4: 0000000000f50ef0
[ 1009.405590] PKRU: 55555554
[ 1009.405591] Call Trace:
[ 1009.405593]  <IRQ>
[ 1009.405596]  ? show_regs+0x6d/0x80
[ 1009.405602]  ? watchdog_timer_fn+0x206/0x290
[ 1009.405607]  ? __pfx_watchdog_timer_fn+0x10/0x10
[ 1009.405609]  ? __hrtimer_run_queues+0x105/0x280
[ 1009.405613]  ? hrtimer_interrupt+0xf6/0x250
[ 1009.405615]  ? __sysvec_apic_timer_interrupt+0x4e/0x150
[ 1009.405619]  ? sysvec_apic_timer_interrupt+0x8d/0xd0
[ 1009.405622]  </IRQ>
[ 1009.405623]  <TASK>
[ 1009.405624]  ? asm_sysvec_apic_timer_interrupt+0x1b/0x20
[ 1009.405628]  ? __pfx_pci_mmcfg_read+0x10/0x10
[ 1009.405630]  ? pci_mmcfg_read+0xcb/0x110
[ 1009.405632]  ? pci_mmcfg_read+0x52/0x110
[ 1009.405633]  pci_read+0x52/0x90
[ 1009.405636]  pci_bus_read_config_dword+0x47/0x90
[ 1009.405640]  pci_read_config_dword+0x27/0x50
[ 1009.405642]  pci_find_next_ext_capability+0x83/0xe0
[ 1009.405645]  pci_find_ext_capability+0x12/0x20
[ 1009.405647]  pci_restore_ltr_state+0x29/0x60
[ 1009.405652]  pci_restore_state.part.0+0x2d/0x3a0
[ 1009.405655]  pci_dev_restore+0x58/0x80
[ 1009.405656]  pci_reset_bus+0xe6/0x360
[ 1009.405660]  vfio_pci_core_disable+0x301/0x450 [vfio_pci_core]
[ 1009.405666]  vfio_pci_core_close_device+0x64/0xd0 [vfio_pci_core]
[ 1009.405671]  vfio_df_close+0x5c/0xb0 [vfio]
[ 1009.405676]  vfio_df_group_close+0x37/0x80 [vfio]
[ 1009.405680]  vfio_device_fops_release+0x25/0x50 [vfio]
[ 1009.405684]  __fput+0x9e/0x2e0
[ 1009.405689]  ____fput+0xe/0x20
[ 1009.405691]  task_work_run+0x5e/0xa0
[ 1009.405695]  do_exit+0x383/0xae0
[ 1009.405700]  do_group_exit+0x35/0x90
[ 1009.405702]  get_signal+0xa8d/0xa90
[ 1009.405705]  arch_do_signal_or_restart+0x42/0x280
[ 1009.405709]  syscall_exit_to_user_mode+0x209/0x260
[ 1009.405712]  do_syscall_64+0x8d/0x170
[ 1009.405715]  ? futex_wait+0x74/0x120
[ 1009.405719]  ? select_task_rq_fair+0x180/0x1b80
[ 1009.405723]  ? kvm_vcpu_ioctl+0x30e/0x800 [kvm]
[ 1009.405772]  ? futex_wake+0x89/0x190
[ 1009.405774]  ? do_futex+0x128/0x230
[ 1009.405776]  ? __x64_sys_futex+0x95/0x200
[ 1009.405777]  ? try_to_wake_up+0x248/0x5f0
[ 1009.405782]  ? syscall_exit_to_user_mode+0x89/0x260
[ 1009.405784]  ? do_syscall_64+0x8d/0x170
[ 1009.405786]  ? futex_wake+0x167/0x190
[ 1009.405788]  ? do_futex+0x128/0x230
[ 1009.405789]  ? __x64_sys_futex+0x95/0x200
[ 1009.405790]  ? do_futex+0x128/0x230
[ 1009.405792]  ? __x64_sys_futex+0x95/0x200
[ 1009.405793]  ? syscall_exit_to_user_mode+0x89/0x260
[ 1009.405795]  ? do_syscall_64+0x8d/0x170
[ 1009.405797]  ? do_syscall_64+0x8d/0x170
[ 1009.405799]  ? do_syscall_64+0x8d/0x170
[ 1009.405800]  ? exc_page_fault+0x94/0x1b0
[ 1009.405802]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[ 1009.405805] RIP: 0033:0x786e7b4dee96
[ 1009.405833] Code: Unable to access opcode bytes at 0x786e7b4dee6c.
[ 1009.405834] RSP: 002b:0000786e763faf60 EFLAGS: 00000246 ORIG_RAX: 00000000000000ca
[ 1009.405836] RAX: fffffffffffffe00 RBX: 0000000000000000 RCX: 0000786e7b4dee96
[ 1009.405838] RDX: 0000000000000000 RSI: 0000000000000189 RDI: 00005ea2032c4d48
[ 1009.405839] RBP: 0000000000000000 R08: 0000000000000000 R09: 00000000ffffffff
[ 1009.405840] R10: 0000000000000000 R11: 0000000000000246 R12: 00005ea202a28c00
[ 1009.405841] R13: 0000000000000000 R14: 0000000000000000 R15: 00005ea2032c4d48
[ 1009.405843]  </TASK>
[ 1012.454784] watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [pvedaemon worke:1598]
[ 1012.454831] Modules linked in: xt_tcpudp nf_conntrack_netlink xt_conntrack nft_chain_nat xt_MASQUERADE xfrm_user xfrm_algo xt_addrtype nft_compat overlay act_police cls_basic sch_ingress sch_htb veth ebtable_filter ebtables ip_set ip6table_raw ip6table_filter ip6_tables iptable_filter nf_tables iptable_raw xt_CT iptable_nat xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 softdog sunrpc mei_hdcp mei_pxp bonding tls nfnetlink_log nfnetlink binfmt_misc mei_gsc mei_me mei xe drm_gpuvm iwlmvm drm_exec gpu_sched drm_suballoc_helper intel_rapl_msr drm_ttm_helper intel_rapl_common snd_hda_codec_hdmi mac80211 edac_mce_amd kvm_amd libarc4 i915 kvm snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec crct10dif_pclmul polyval_clmulni polyval_generic ghash_clmulni_intel snd_hda_core drm_buddy sha256_ssse3 ttm sha1_ssse3 btusb snd_hwdep iwlwifi btrtl aesni_intel drm_display_helper snd_pcm btintel btbcm crypto_simd cec snd_timer btmtk cryptd rc_core bluetooth snd wmi_bmof rapl video cfg80211 mxm_wmi soundcore
[ 1012.455068]  pcspkr ecdh_generic k10temp ccp ecc joydev input_leds mac_hid zfs(PO) spl(O) vhost_net vhost vhost_iotlb tap vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd efi_pstore dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic xor raid6_pq hid_logitech_hidpp hid_logitech_dj hid_generic usbkbd usbmouse usbhid hid dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c xhci_pci nvme xhci_pci_renesas crc32_pclmul igb i2c_piix4 nvme_core ahci i2c_algo_bit xhci_hcd libahci dca nvme_auth wmi
[ 1012.455305] CPU: 3 PID: 1598 Comm: pvedaemon worke Tainted: P        W  O L     6.8.12-2-pve #1
[ 1012.455324] Hardware name: To Be Filled By O.E.M. X570 Taichi/X570 Taichi, BIOS P5.63 08/22/2024
[ 1012.455337] RIP: 0010:native_queued_spin_lock_slowpath+0x229/0x2d0
[ 1012.455367] Code: 4e 01 41 c1 e5 10 c1 e1 12 44 09 e9 89 c8 c1 e8 10 66 87 43 02 89 c2 c1 e2 10 81 fa ff ff 00 00 77 37 31 d2 eb 02 f3 90 8b 03 <66> 85 c0 75 f7 89 c6 66 31 f6 39 ce 74 7e c6 03 01 48 85 d2 74 0e
[ 1012.455407] RSP: 0018:ffffb17200de7a68 EFLAGS: 00000202
[ 1012.455433] RAX: 0000000000580001 RBX: ffff9348542c8e68 RCX: 0000000000100000
[ 1012.455456] RDX: ffff93573e7b59c0 RSI: 00000000004c0101 RDI: ffff9348542c8e68
[ 1012.455479] RBP: ffffb17200de7a88 R08: 0000000000000000 R09: 0000000000000000
[ 1012.455493] R10: 0000000000000143 R11: 0000000000800001 R12: ffff93573e3b59c0
[ 1012.455505] R13: 0000000000000000 R14: 0000000000000003 R15: ffff934845894618
[ 1012.455516] FS:  00007ed2693feb80(0000) GS:ffff93573e380000(0000) knlGS:0000000000000000
[ 1012.455531] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1012.455542] CR2: 000074ec89818010 CR3: 000000012d58c000 CR4: 0000000000f50ef0
[ 1012.455555] PKRU: 55555554
[ 1012.455563] Call Trace:
[ 1012.455571]  <IRQ>
[ 1012.455583]  ? show_regs+0x6d/0x80
[ 1012.455605]  ? watchdog_timer_fn+0x206/0x290
[ 1012.455624]  ? __pfx_watchdog_timer_fn+0x10/0x10
[ 1012.455640]  ? __hrtimer_run_queues+0x105/0x280
[ 1012.455656]  ? clockevents_program_event+0xb3/0x140
[ 1012.455677]  ? hrtimer_interrupt+0xf6/0x250
[ 1012.455693]  ? __sysvec_apic_timer_interrupt+0x4e/0x150
[ 1012.455708]  ? sysvec_apic_timer_interrupt+0x8d/0xd0
[ 1012.455725]  </IRQ>
[ 1012.455731]  <TASK>
[ 1012.455738]  ? asm_sysvec_apic_timer_interrupt+0x1b/0x20
[ 1012.455762]  ? native_queued_spin_lock_slowpath+0x229/0x2d0
[ 1012.455781]  _raw_spin_lock+0x3f/0x60
[ 1012.455797]  igb_get_stats64+0x23/0x90 [igb]
[ 1012.455858]  dev_get_stats+0x5e/0x120
[ 1012.455872]  dev_seq_printf_stats+0x49/0x100
[ 1012.455890]  dev_seq_show+0x14/0x40
[ 1012.455900]  seq_read_iter+0x2c6/0x4a0
[ 1012.455920]  seq_read+0x11e/0x160
[ 1012.455937]  proc_reg_read+0x69/0xb0
[ 1012.455953]  vfs_read+0xad/0x390
[ 1012.455970]  ? putname+0x5b/0x80
[ 1012.455987]  ? do_sys_openat2+0x9f/0xe0
[ 1012.456000]  ksys_read+0x73/0x100
[ 1012.456017]  __x64_sys_read+0x19/0x30
[ 1012.456031]  x64_sys_call+0x23f0/0x24b0
[ 1012.456046]  do_syscall_64+0x81/0x170
[ 1012.456061]  ? tick_sched_handle+0x32/0x70
[ 1012.456076]  ? timerqueue_add+0xa6/0xd0
[ 1012.456089]  ? mutex_lock+0x12/0x50
[ 1012.456106]  ? seq_lseek+0x88/0x100
[ 1012.456122]  ? proc_reg_llseek+0x5a/0x90
[ 1012.456137]  ? ksys_lseek+0x7d/0xd0
[ 1012.456150]  ? syscall_exit_to_user_mode+0x89/0x260
[ 1012.456168]  ? do_syscall_64+0x8d/0x170
[ 1012.456182]  ? irqentry_exit_to_user_mode+0x7e/0x260
[ 1012.456200]  ? irqentry_exit+0x43/0x50
[ 1012.456217]  entry_SYSCALL_64_after_hwframe+0x78/0x80
[ 1012.456234] RIP: 0033:0x7ed26953419d
[ 1012.456291] Code: 31 c0 e9 c6 fe ff ff 50 48 8d 3d 66 54 0a 00 e8 49 ff 01 00 66 0f 1f 84 00 00 00 00 00 80 3d 41 24 0e 00 00 74 17 31 c0 0f 05 <48> 3d 00 f0 ff ff 77 5b c3 66 2e 0f 1f 84 00 00 00 00 00 48 83 ec
[ 1012.456311] RSP: 002b:00007ffdef69f858 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
[ 1012.456326] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007ed26953419d
[ 1012.456337] RDX: 0000000000002000 RSI: 00005a68a715c840 RDI: 000000000000000b
[ 1012.456354] RBP: 0000000000002000 R08: 0000000000000000 R09: 00007ed26960ed30
[ 1012.456368] R10: 00005a68a715c840 R11: 0000000000000246 R12: 00005a68a715c840
[ 1012.456384] R13: 00005a689efd52a0 R14: 000000000000000b R15: 00005a68a71576c0
[ 1012.456411]  </TASK>
[ 1013.404143] watchdog: BUG: soft lockup - CPU#18 stuck for 27s! [pvestatd:1575]
RandyT_Intel
 Hello simon007,
Thank you for providing your system information regarding the high  power consumption on Intel Arc Graphics Desktop cards.
I have identified a resolution for the issue on Windows operating systems, and I have attached the relevant article for your reference. However, as you are currently using Linux, we will need to conduct additional analysis with our internal team to address this specific situation.
High Power Consumption when Intel® Arc™ Graphics Card is...
I will keep you updated and will get back to you as soon as we have further insights or recommendations. Thank you again for your patience.
Randy T.
RandyT_Intel
Hello simon007,
I wanted to provide you with an update based on the feedback from our internal team regarding your inquiry. It appears that ASPM is now functioning correctly with Proxmox. However, the current challenge lies in achieving a GPU passthrough to a virtual machine (VM).
Unfortunately, it's important to note that Intel Arc GPUs (A-series) do not support passthrough functionality. For further information on this limitation, please refer to the following link: Graphics Virtualization Technologies Support for Each Intel®...
Randy T.
RandyT_Intel
Hello simon007,
I wanted to follow up regarding the information we shared with you recently. Have you had a chance to review them? Your feedback is invaluable in helping us determine the next best course of action.
Please let me know if you have any thoughts or if there's anything else you need from us.
Looking forward to your response!
Randy T.
simon007
Thank you. yes, aspm works fine now, if not passthrough it.
howver I'm not using SR-IOV, but rather passthrough the entire graphics card. as amd, nvidia all support. The only remaining issue at present is
1. after long search. maybe the audio of that card has some bug, if not passthrough the audio, the card works fine. no need to clean reset method
2. aspm still not work only when passthrough the card, even rebound to host after passthrough
thanks for replay
dacianb
Hello there, can confirm i have the exact same issue. I also use Proxmox and if i restart the host, the ARC A770 basically enters a low power state with negligible power draw (even the fans spin down). If i do a passthrough to a VM (ubuntu 24.04) the card starts drawing arounf 30-40W even though nothing i running, no even a monitor is connected to the card. If i turn off the VM, the card keeps drawing 30-40W no matter what i do.
I want to use the card for local LLM inferencing but as it stands it's kinda unusable since it draws around 50% of my homelab setup while idling.
I am thinking of using it on the host (Proxmox) directly without a VM but the Intel drivers are only for Ubuntu, so i'm stuck there as well...
Any ideas would be pretty much appreciated!
simon007
you can try use lxc and bind drm to lxc.I used this method when I was using stable diffusion before.
dacianb
I tried to use the host (debian bookworm) i915 free and non-free driver but when the driver loads the card starts drawing 30-40W at idle, it seems to me that the actual driver is the problem. I also tested a AMD Rx 7600XT 16GB witch is a similar card (190W TDP vs 225 W TDP of the ARC) and in the same scenario (no display output, driver loaded, host and pass-through) draws around 4-5W at idle.
I really do think this is a driver issue, but i also think Intel is not to interested in fixing this...
RandyT_Intel
Hello simon007,
Thank you for your feedback. We appreciate you taking the time to share your experience with us.
We will raise this information to our internal team for further checking. Your insights are valuable, and we will use this feedback for our future improvements to enhance user experience.
Randy T.
